Nitto 555R vs BFG G-force Drag Radials
Nitto 555R Drag radials 245/50/16 25.6 lbs
Bfg G-force t/a Drag radials 255/50/16 33.7 lbs
Good to know since I ordered two in 245/17 555Rs for the drag session on the 12th.
Second- I am coming from a past of cars with glass rear-ends. Will the C55 in stock form hold up with some heavy launching on DR's?
Thanx!
Alex
Thanx!
Alex
I will be driving back and forth to the track(60 miles) so I didnt think the Hoosiers were a good chioce for me. Hey Mustang281man, I am loving the pullies, I can feel a noticable difference in the car. Thanks again.
The Nitto's are by far the best for daily usage. I ran them on my Z28 for 5+ years, and they handled just fine, and were good in the rain as long as they still had tread. Once the middle tread is gone they'll hydroplane like any other tire would. I also was able to cut a 1.60 60' time on an 11.43 pass with them. Typically I could get about 8,000 miles out of a set w/ a few track visits in between.
The BFG drag radial is by far a better traction tire than the Nitto for the drag strip, but it's not good in the rain, and you'll only get about 5,000 miles out of it per the softer composition.
The new Mickey Thompson drag radial is the absolute best of any of them for traction purposes, as there are 9-second cars using them w/ no problem. However, you'd never want to have them on a wet road, as they have virtually no tread at all. In essence they are a racing slick w/ a few grooves cut into them --- just enough to be considered D.O.T. approved. In reality they are a track-only tire, or a Saturday eve cruising tire in dry weather.
Now, unless you plan on doing some monsterous mods to your C55, the Nitto would be more than adequate for traction on the street and track. Like I said, I cut 1.60's with mine and I was hitting them w/ 441 rwhp and 448 rwtq. They are by far the best option for a daily driven tire. If you plan on modding enough to be even a mid-12 second 1/4 mile car, these will be all you need. Heck, I have a friend who runs the Michelin PS2's on his C55, and he can barely break them loose on dry concrete, so a Nitto DR would easily cover your needs.
