Another ticking noise..
Old Apr 23, 2008 | 02:23 AM
RW C55's Avatar
'10 E63 Obsidiant Black; '06 R350 Alabaster White; 05 C55 Obsidiant Black (sold)
My car seems to be having lots of ticking noises...
So i just got my previous ticking noise problem fixed, but now there's another ticking noise.
When I drive pass 50km, there is a weird ticking noise coming from driver rear wheel. The ticking noise increases as the speed adds up. I was unable to hear it from outside when I have my windows opened...
What would the problem be?
Old Apr 23, 2008 | 09:21 AM
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
Check to see if there is anything stuck to your drive wheel, or if there is a nail puncture into your tire.
Old Apr 23, 2008 | 11:50 AM
RW C55's Avatar
I checked, but there wasnt anything in the tire..
Old Apr 27, 2008 | 12:30 AM
power-fade's Avatar
"One Man. One Engine."
Maybe a wheel bearing problem?
Old Apr 27, 2008 | 12:39 AM
RW C55's Avatar
Weird.. after a few days this noise just dissappeared.
Still can't figure out what it was.
Old May 27, 2008 | 01:12 PM
360_iti's Avatar
W203, W211, W219, W212
OK I got one similar to what he described, only mine happens at lower speed and won't go away.
These are the characteristics:
1. Ticking noise only happens at the end of the trip after the engine warms up, or during warm sunny days. Never happened in the morning when I leave for work.
2. The frequency of the ticking goes along with speed, and it seems to blur with the sound of the engine past 20mph. But at a lower speed, for example when I drive in to my garage I can hear the ticking clearly. The noise itself is not loud, but defined. I can't hear them with the windows open.
3. No ticking at all when the engine is at idle.
4. It comes from the passanger side and I'm almost sure it's from the front.
Does anyone have this problem too or know how to fix this? Thanks.
Old May 28, 2008 | 12:03 PM
AdamsSLK's Avatar
2004 SLK32 AMG
I have this ticking sound too; you've done a much better job at describing it! Unfortunately, I haven't been able to take care of it. I just dropped the car off at the stealer for this issue among others, so if they find the cause I'll share it.
Old May 28, 2008 | 12:13 PM
360_iti's Avatar
Thanks Adam, yes, please let us know.
Old Feb 2, 2009 | 09:47 AM
Tee-boy's Avatar
I own an ML 320 , C 240 and Audi TT
@ AdamsSLK
I know it is an old post but did u manage to solve this problem ? i just bought a c240 and it has the same symptoms .
Old Feb 2, 2009 | 09:49 AM
AdamsSLK's Avatar
2004 SLK32 AMG
Sorry, guys, I wish I could offer more insight but the dealer had no idea and didn't really acknowledge that it was still there. I eventually just resigned myself to the idea that it was simply a part of that engine, but I just sold the car this weekend so it isn't an issue for me any more :/
Old Feb 2, 2009 | 12:24 PM
jturkel's Avatar
02 C32 AMG
i have it.....i think it is something rubbing on the drive shaft or loose heat shield material underneath the car hitting it.
Old Feb 2, 2009 | 01:23 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Sounds like a good diagnosis here. I had this issue (not under warranty) about 1.5 years ago. It is a very expensive part and leaving it be could be dangerous. My SA said that the material can actually catch fire if it is left alone, rubbing the drive shaft. The cheap fix was to cut away the offending piece of material and all was good again.
