Can someone chime in with dual skid marks
Now when I pulled up in the driveway and nailed it I left 2 skid marks up the driveway. I swear last time I did that I only got one spinning. I am not sure if I had traction on or off.
Is this correct:
With traction control on both tires will lay a patch's but power will be cut to the engine when traction is lost.
With traction control off you get one wheel spinning but only limited power loss intervention.
Is this correct:
But, in answer to your question, I think that with ESP off properly, you will spin both wheels (i.e. by disabling the ESP and other safety features through the 'dyno mode'). With ESP on, the computer should cut/decrease power to the wheel that is spinning.
Unless the vehicle has an aftermarket LSD installed (e.g. Quaife ATB), most stock-diff C32 owners wind up having massive wheelspin from just one wheel when in 'dyno mode.'
Thanks for pointing that out.
Unless you have a Quiafi, in Dyno mode, the car is a one wheel smoker. Heck I tired it at the track, and FORGET IT! Massive one wheel spin out of EVERY right hander. Now, with the ESP off, aka fake diff, you still get good power to the ground as the electronics are still in affect.
Leave DYNO mode to just that DYNO time. ITS worthless on the street, unless you just want to toast a SINGLE tire
See yeah
I will have to test it again next week. I swear last time I did it with ESP off (Not In Dyno Mode) I got rubber out of one tire. Then with it on I think I got rubber out of two. Maybe if I had it on that is how I got dual marks. Maybe when one was slipping it would puts the power to the other tire and keeps going back and forth between the two.
All I know is there where 2 black lines from the rear for about 10-15 feet. I just bumped it real quick and let off so as not to go through the garage
Unless you have a Quiafi, in Dyno mode, the car is a one wheel smoker. Heck I tired it at the track, and FORGET IT! Massive one wheel spin out of EVERY right hander. Now, with the ESP off, aka quasi off, you still get good power to the ground as the electronics are still in affect.
See yeah
If a LSD installed C32 in Dyno mode still spins one tire massively then we are back to square one and we don't have a way to tell unless told by previous owner if a LSD was installed.
I know for sure when I shut off ESP I only get one wheel spinning. This leads me to believe I had ESP on and power was being provided to both tires. The weird part is I did not feel the engine cut out on me though. I have layed into the gas before with ESP on and just as soon as the car starts to break loose it cuts power which it is susposed to do.
I asked the guy when I bought the car if he had done anything to it and he said no. I bought it new and it is all stock.
All I know now is I have two dual black marks up part of the driveway. Boy I wish I remembered if I shut of ESP or not. Well I will test it out when we return from Disney next week.
Sorry I missed you while I was out there. Hope you had a great time with the vacation thing.
ESP ON = no wheel spin, power cut down almost instantly
ESP OFF= both tires spining leaving nice parallel line of rubber
ESP DYNO mode = one wheel spining until you grind your rims.
regards
Jack
Now that I have the Quaife installed:
ESP ON : equal spin both tires under moderate throttle, no power cut
ESP OFF: both tires spin, but the car no longer tries to fishtail
Dyno Mode: both tires spin
