Need help on P0365 & P0366
Old May 9, 2008 | 02:51 AM
name911's Avatar
Hi.
Could someone help me on my C class W203 Year 2004. I got the CEL and I scan the OBDII got 2 code P0365 & P0366. But I have no Idea which part should I replace..
Thanks in advanced..
Old May 9, 2008 | 10:43 AM
c32used's Avatar
LET C32 2002
I will check
Old May 9, 2008 | 11:07 AM
Eurocharged Rick's Avatar
SPONSOR
those numbers don't come up in the OBDII database, are you sure they are correct?
Old May 9, 2008 | 11:30 AM
neihouma's Avatar
02 C32 AMG sold!
http://www.eastcoastefi.com/obd2codes.pdf
One side of the camshafts seems to taken a dump?
Old May 9, 2008 | 11:44 AM
ohlord's Avatar
Try
checking the wires to the unit and that the harness is plugged in.
Are you having any problems starting the car?
Clear the codes and see if it was a temporary condition that triggered the light.
http://www.autohausaz.com/search/pro...rk%20%20Sensor
easy diy located on the front of the passenger side head.
ohlord
Old May 9, 2008 | 12:01 PM
name911's Avatar
Yes, both code got from OBDII that I bought from Habor frieght. It say something about Camshafts sensor..but have no idea what to do with it..
Old May 9, 2008 | 12:04 PM
SPONSOR
yes, clear the code and see if it comes back....if it does, you may be having some valvetrain issues...
Old May 9, 2008 | 12:07 PM
name911's Avatar
ohlord
Thanks Ohlord.
I cleared the code couple times already, but it still come back after I start the engine couple time...so you mean I have to replace the Camshafts sensor? but as I know there are two of them so which one should I replace.
Please advice.
Old May 9, 2008 | 12:11 PM
c32used's Avatar
LET C32 2002
Pretty fast responces guys
Old May 9, 2008 | 12:50 PM
name911's Avatar
Thanks 1FASTC32
Yes, I cleared its couple times already but still come back on.
Old May 9, 2008 | 01:09 PM
ohlord's Avatar
M112
engine only has one cam sensor that's why the code most likely shows bank1 which looking from the front of the car is left side pass side.Look on the front of that head and you will see the wires leading to the unit pictured in the autohausaz.com link.Replace the unit and you should be good to go.
ohlord
Old May 9, 2008 | 01:30 PM
name911's Avatar
ohlord
Thanks for your help. I will place an order and have it replaced ASAP...
Old Mar 6, 2016 | 06:19 PM
verlin samonte's Avatar
E200 2002 kompressor
Is the p0365 gone? What were inspectednor replace?
Old Mar 7, 2016 | 08:12 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
this thread is from 2008. Come on.
