Code3 phenolic spacers installation?
Old Jun 25, 2008 | 04:11 PM
gtr886's Avatar
E63 W211 08, C32 W203 02
Question Code3 phenolic spacers installation?
Does anyone know how to install the code3 spacer?
I have Two spacers, four washers, two gaskets, two bolts, and two silicon couplings.
1. Where do i put the gasket? on top or bottom of the spacer?
2. Where so i put the two silicon couplings?
3. What torque on those bolts?
Old Jun 25, 2008 | 06:29 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
I'm assuming that, since you're asking, you didn't receive any instructions
Anyway, I just did this install recently, albeit the LET version. First thing I noticed about your parts listing - you don't have everything you need, unless C3P's phenolic spacers are a different design, because you need 4 MB gaskets... one above and one below each side's spacer and washers. Maybe it's intended for you to re-use the stock ones? Generally speaking, that usually is never advised... it's too cheap and easy to just replace all with new.
I have no idea what the silicon couplings are for... my guess, however, is to replace the stock intercooler y-pipe's rubber hoses.
Torque on the bolts should be just under 15 ft-lbs - they don't take much. If you have a smaller torque wrench with in-lbs, it would be 177 in-lbs, or 20 Nm.
Sounds like you've purchased most of the products C3P offers for the C32 - are you still having difficulty reaching Brandon?
Old Jun 25, 2008 | 10:10 PM
gtr886's Avatar
Anyway, I just did this install recently, albeit the LET version. First thing I noticed about your parts listing - you don't have everything you need, unless C3P's phenolic spacers are a different design, because you need 4 MB gaskets... one above and one below each side's spacer and washers. Maybe it's intended for you to re-use the stock ones? Generally speaking, that usually is never advised.......
Yes! i can't reach this guys. He doesn't even respond any e-mails. When i placed my order one months ago, i stated that i need the instructions on how to install your parts. So far, all i have is incomplete shipment and troubles with the spacer. I even have to look up other post on installing the intake from code3.
Old Jun 25, 2008 | 11:24 PM
gtr886's Avatar
Question
3. What torque on those bolts? and where do they go?
Any Pictures????
Old Jun 25, 2008 | 11:39 PM
mikekuriger's Avatar
2010 C63
gaskets? I've always just replaced gaskets with the phenolic spacers. Never tried using both together. What are the spacers made out of? Mine are teflon.
~mike~
Old Jun 26, 2008 | 11:45 AM
gtr886's Avatar
Question
Old Jun 26, 2008 | 12:28 PM
razormb's Avatar
CLA
Also would like to know the answer to this. I was going to put the gasket below the spacer but not %100 sure. Can anyone chime in on this? I pulled off the old coupling and will replace it with the C3 one. Ill let you know if it works -but I imagine its longer than the original in order to compensate for the added thickness of the spacer.
Old Jun 26, 2008 | 12:47 PM
///AMG4EVER's Avatar
CLS55 Designo 030
You need two pair of gaskets, one on top and one on the bottom (on each side of course)... I think that's what I have.
Old Jun 26, 2008 | 01:23 PM
MRAMG1's Avatar
S600, GL450, GLC 43
+1
That is waht is required, NO options here guys. And yes, that is what I did for mine. They are really cheap from the stealer, about $9 each. GET 4 Total, or you will end up with a leak.
See yeah
Old Jun 26, 2008 | 01:29 PM
gtr886's Avatar
Code3 only comes with two gasket with their spacer.
Old Jun 26, 2008 | 02:53 PM
c32used's Avatar
LET C32 2002
+1
Old Jun 26, 2008 | 03:23 PM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
Whats up with Code 3? Im glad I didnt order anything from him. I am hearing similiar things from a person in Germany that ordered parts.
Old Jun 26, 2008 | 03:53 PM
c32AMG-DTM's Avatar
The only remotely possible reason I can foresee for this, is that C3P might expect you to reuse the 2 stock gaskets you already have, assuming they look to be in okay condition. i.e. leave the stock gaskets on the intake, then place the spacers and washers, and add a new gasket on top. If I were you, I'd buy two more, and use 4 new ones, like I mentioned earlier.
As for the two bolts you have - my guess (and it's just a guess) is that you need new front bolts (i.e. closest ones to the front bumper) because of the thickness of the C3P spacer... IIRC, it's twice as thick as the other versions on the market. Your stock bolts are three different sizes - you'll notice, once you've started the install.
Good luck... sorry to hear that you're having post-sale customer service issues - hopefully that is rectified for you in a timely fashion.
Old Jun 26, 2008 | 04:03 PM
CLS55 Designo 030
+1. Good call on the bolts...
Old Jun 26, 2008 | 07:52 PM
hkycoldrct's Avatar
2002 C32 ///AMG
Any Pictures????
Small suggestion on the bolt torque spec. Just snug them down and hand tighten them. If there's a leak give them another quarter or half turn. I snapped one of the 110mm bolts following the torque spec....lucky for me the bolt snapped vs. stripping the threads on the SC. Just me .02.
Old Jun 29, 2008 | 11:09 PM
gtr886's Avatar
Question do you know how to install the code3 Phenolic Spacers?
do you know how to install the code3 Phenolic Spacers? ANy DIY with PIC????
Old Jul 2, 2008 | 12:56 PM
razormb's Avatar
CLA
1) I started by putting on the coupling and clamps and getting them in place first. Next I started to bolt everything down. This pic shows the gaskets and spacers with a test fit prior to being screwed down.
2) One more Note: I replaced my lower oem gaskets -part# 112 098 00 80 Thanks to Splinter's post.
3) This shows the bolt placement.. the first (black) one is provided by Code3. I found it easier to screw the first one down to hold the tank and then focus on middle and rear.
4)This shows the spacers for the outside screws in place.
Old Jul 2, 2008 | 06:25 PM
Newzchspy's Avatar
PLAID
Need all new Bolts for Phenolic Spacers??
Now that I am getting into the spacer project NOW, enlighten me. Do you need ALL NEW longer bolts and are they provided from either LET or Code III or are the stock ones enough??
Glenn
Old Jul 2, 2008 | 07:17 PM
razormb's Avatar
CLA
Glenn
You reuse your stock bolts except for the one in the front. Code3 will give you 2 new bolts for that. Everything leveled out gr8 when I was done.. it will all make sense when you do it
Old Jul 2, 2008 | 09:39 PM
c32AMG-DTM's Avatar
Glenn
If you use LET's, you don't need any extra bolts, couplings, etc. Just 4 new gaskets (which they provide), the spacers, and the washers. Erick also will forward you the step-by-step illustrated instructions (razormb's are essentially the same, however - just a couple extra steps for C3P).
Two tips - use the stock gasket as a template to get the bends right in your new gaskets, and start with the bolts closest to the supercharger before doing the two that use the washers. Good luck - when mine were installed, the driver side went easy, and then had a heck of a time getting the passenger side plenum to line up just right... overall it's a pretty easy install, though, once you have instructions. Good luck!
Old Jul 3, 2008 | 12:23 AM
razormb's Avatar
CLA
Instructions from Code3!
http://www.code3performance.com/C32/spacer_install.html
