dyno mode or esp off for track ?
Old Jul 9, 2008 | 11:54 AM
twinttsvr4's Avatar
02 c32 amg 94 3000gt vr4
going to the track tonight, just wondering if i should put the car in dyno mode or just turn esp off
Old Jul 9, 2008 | 12:09 PM
bud4ya's Avatar
2003 C32 AMG, 2003 E39 M5
I would think you would not want it in dyno mode due to traction coming out of the corners on hard acceleration.
I am not a track expert though
Old Jul 9, 2008 | 12:56 PM
dkflipse's Avatar
C32 AMG
esp off
Old Jul 9, 2008 | 01:45 PM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
Auto X, 1/4 mile, road course? For all ESP off is the right choice. Dyno mode will have you roasting one rear tire.
Old Jul 9, 2008 | 02:05 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
right on the money.....
Old Jul 10, 2008 | 01:20 AM
twinttsvr4's Avatar
well i ran it in the 1/8th mile with esp off. the closest 1/4 mile track is an hour away...i could not stop spinning all night though. my best time was a 9.003 at 79.90 with a 2.18 60ft. and i did about 10 more runs almost identical. always 9.0 something with one or two hot laps at 9.1xx. is this really a decent 60ft time though? i mean 2.1's all night on what i consider to be a pretty well prepped track. I was spinning almost all the way to the 60. the car is stock but just had its service done so new filters and oil and what not. this is my first rwd car. i guess i've been pretty spoiled by consistent 1.70's.
other track info
95+ degrees Faranhiet out for most of the day
dropped into the mid to low 80's at night
Old Jul 10, 2008 | 02:40 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
If the track prep was bad, then you need to put ESP on.
I played with dyno mode, and the brake balance is not set up for running without ABS.
Old Jul 11, 2008 | 03:05 AM
JToups386's Avatar
2005 C55 AMG
other track info
Not to make you sad or anything, but if you're running 9.00 @ 90mph in the 1/8 mile, that equates to approximately a 14.10 in the 1/4 mile @ 100mph. 2.1 sixty foot times are certainly acceptable for a radial tire. You might squeeze out a high 1.9-ish or 2.0 on a really good night.
The standard accepted formulas for translating 1/8 mile to 1/4 mile ET's are:
Multiply your 1/8 ET by 1.57
Multiply your 1/8 MPH by 1.25
I've used this formula for many years, and it is typically very accurate overall. I've had slight variances on my turbo Buick w/ it, but my N/A Z28 used to be within hundredths of a second per the formula.
You definitely have room for a little improvement in your ET and MPH. However, you weren't running in ideal atmospheric conditions either. Keep in mind a tenth off your 60' is typically worth 2 tenths in your 1/4 ET. For example, if you drop your 2.1 on a 14.10 pass, down to a 2.0, you'll likely drop your ET to approximately 13.9.
I've had my best success running in dyno mode at the track, since the ESP absolutely kills the car off the line. I've found I can feather it myself better than letting it try to drive for me. But, that's just my of doing it, and your results may vary...
Old Jul 11, 2008 | 10:48 AM
c32used's Avatar
LET C32 2002
+1
Old Jul 11, 2008 | 10:53 AM
c32used's Avatar
LET C32 2002
other track info
I saw practice your launch to get less spin...try different things...practice loading convertor to 1k-1200prm then let go gradually once moving hit it to WOT it should reduce wheel spin but if done too slow it will not give you better times.
PRACTICE, PRACTICE, PRACTICE...
Old Jul 11, 2008 | 03:15 PM
jturkel's Avatar
02 C32 AMG
Originally Posted by c32used
I say practice your launch to get less spin...try different things...practice loading convertor to 1k-1200prm then let go gradually once moving hit it to WOT it should reduce wheel spin but if done too slow it will not give you better times.
That's what I did to improve my launching skills on this car. A combination of all of that ^
