Got Carbon? [Updated Pics]
Old Jul 24, 2008 | 01:07 PM
///AMG4EVER's Avatar
CLS55 Designo 030
As some of you know, I'm a carbon fiber freak. From time to time, I get PMs inquiring about some of the CF goodies in the car. I'm not an expert taking pictures as you are about to see but I wanted to share it with my C32 brothers.
Special thanks goes to my good friend Erick and the rest of the LET team (Jerry & company), Sunil at Motorwerks and everyone else that has offered their input throughout the last 3 years owning this beast. Enjoy!
Old Jul 24, 2008 | 01:10 PM
rlee02135's Avatar
2004 C32 ///AMG
that's simply beautiful
Old Jul 24, 2008 | 01:12 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
nicely done...that is a lot of carbon.....
Old Jul 24, 2008 | 01:20 PM
pshek's Avatar
2003 C-Class Sportcoupe
That CLK cluster is
How long have you had the intake overlayed in CF? My overlay on the airboxes is starting to show signs of heat damage. Looks okay still, but the resin is boiling off/curing from the engine heat, so the surface is not as smooth as when it was new. You might want to put some heat barrier under the airboxes to make the overlay stay looking new. I wish I had done that when I first had it overlayed. I'll probably need to add some clear resin to the top of the airboxes and wet sand/clear coat later.
Old Jul 24, 2008 | 01:28 PM
ArsnlKen's Avatar
02 w203,85 w123
beautiful-ESPECIALLY THAT GRILLE!
AMG4...just killer,dude!
Old Jul 24, 2008 | 01:32 PM
CLS55 Designo 030
Originally Posted by pshek
That CLK cluster is
Thanks guys!
I had for the covers for a while but I just installed them last week... I had the 55 full setup and I wanted to give the C3P intake a try so I switch it back... next in line is the LET intake for sure. I have to figure out a way to maintain the stock CF look.
You are 100% correct... I was paying close attention to it this past weekend and I noticed some bubbles in the layers. We'll see if it gets worst.
I meant to PM you the other day. Did you sell your Quaife yet?
Old Jul 24, 2008 | 01:38 PM
CLS55 Designo 030
Thanks for the props. I've tried 4 different grills and finally found the one that I like. The grill is manufacture by Mattig in Germany. I really recommend it... it's not expensive and it's very nice. It was a bit of a pain to get it because they don't sell to the US. I had to buy it through a contact in Europe.
Old Jul 24, 2008 | 02:16 PM
1qikctr's Avatar
Merc power
I'm in love with ur CLK CLUSTER damm it. I have a qs, if i have the voice command...would the change of the CLK cluster affect the voice command?
Old Jul 24, 2008 | 02:27 PM
CLS55 Designo 030
The cluster needs to be programmed via STAR. All your parameters can be translate to the new cluster including your voice command feature.
Old Jul 24, 2008 | 02:59 PM
1qikctr's Avatar
Merc power
I'm sooooo jealous I want this
Old Jul 24, 2008 | 03:20 PM
turbo16lbs's Avatar
1991 Toyota MR2, 2002 C32 AMG
Send me a PM. I would like to know who does your carbon fiber work.
Old Jul 24, 2008 | 03:28 PM
pshek's Avatar
Thanks guys!
You might want to put some heat shield under the airboxes. It's not expensive stuff anyway. Engine heat will slowly cause more bubbles to appear in the resin.
I still got the quaife LSD in the C32 differential. Got the bolt up type axles too. I got the diff and axles used and had them refurbished as new. The LSD is new too. Should be easy for someone to DIY install it with a little help. Still waiting for more interest in it, but I did get an offer for $2300 from someone a few weeks ago.
I've been trying to get it working on my car but couldn't and sadly had to switch back to the old diff+phantom grip. Anyways, I got it all in a box in my garage.
Old Jul 24, 2008 | 04:40 PM
c32used's Avatar
LET C32 2002
Old Jul 24, 2008 | 05:29 PM
CLS55 Designo 030
Front Lip - Euroteck (this is my 3rd one and Neal has been great)
Interior Trim - bought from a forum member, have no clue where he got it
Door Pins - brand: Fabulous, through the local distributor
Cluster CF layer - got this from a banned forum member, he was not a sponsor. It's dry CF, I had to modify it a bit since it was based on the W211 cluster but I'm happy with it
MB CF Caps - ebay (got with a flashlight that no longer works)
License Plate Frame - dealer
Shift Knob - SL designo knob w/ CF overlay*
Rear Spoiler - OEM C55 w/ CF overlay*
Engine Covers - stock 32 setup w/ CF overlay*
*I gave all my parts to Erick (1FASTC32) and he took care of it. It took a while though. I don't know if he is going to advertise this service through LET but you should check into it.
Even my SS brake lines have the CF "look" which I have no idea what I was thinking when I bought them. Now, I would like to address that all this crap is for looks only and has not affect the car's performance
http://www.dragtimes.com/2002-Merced...eos-14185.html
Old Jul 24, 2008 | 05:33 PM
CLS55 Designo 030
I will do that, thanks for the advice.
I want that Quaife but as you know I already have the C32 pumpkin and I don't need all those extra parts. Good stuff you have over there, hopefully you won't give up on it.
Old Jul 24, 2008 | 06:42 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
everything looks great except don't like the fact the clk gauge only goes up to 160mph. lol how much was the cluster again? too bad I don't think my 02 will work with that tho.
+1 on the CF overlay issue. actually any CF parts in engine bay will eventually get cooked and start to break down because majority of these CF parts are held together by resin and not the real high pressure high temp cooked CF parts.
Old Jul 24, 2008 | 06:59 PM
SilverBulletAMG's Avatar
C32 AMG
Did you paint your "C32" and benz star on the trunk black or did it come that way? Love the look and I'd love to get a black set like that. I assume it's black and not carbon on that at least?
Rest of the car looks simply amazing! Great job!
Old Jul 24, 2008 | 07:21 PM
andy_meng1024's Avatar
2003 SL55, 2010 C63
Wow, that looks really nice.
Old Jul 24, 2008 | 08:48 PM
c32 dan's Avatar
c32 amg
carbon
the car looks well cool i like the dash board,can the dashboard be changed to your one??mine is the 02 model??
Old Jul 25, 2008 | 01:58 AM
Eurocharged Rick's Avatar
SPONSOR
thanks for posting up the pics Carlos!
we will have a CF kit available very shortly for these vehicles, if you want to put your name on the list just let me know...
Old Jul 25, 2008 | 05:04 AM
jturkel's Avatar
02 C32 AMG
looks amazing! what is the little emblem on the cover for that coil holder/storage space below the AC controls in the picture?
Old Jul 25, 2008 | 10:46 AM
CLS55 Designo 030
Thanks man. When I bought the mattig grill, the contrast of the flat black was a bit too much on the silver; so I bought extra emblems (V6K, C32, MB star) and color-matched them flat black. I took the old ones out and replaced all of them with new ones. Also, the 3 bumper grills are painted flat black. The original ones are a shinier. It's a great subtle mod that blends the car better.
I've been thinking about painting the grill on top of the hood flat black but I don't know if that would be crossing the line.
Old Jul 25, 2008 | 10:51 AM
CLS55 Designo 030
Yes dude, this 2002 C32 is 7 years old w/ 110K miles on it. See my post above on the details.
