JR-Industries Pillar Pod C32/Slk32
a c55 running around with these is pointless as they are NA. The only C55 interior mod is to replace that coupe air conditioning controls to the superior one found in the mighty C32.
I will use them for the gauges when i add the supercharger from kleemann, then of course...i will be smokin your c32 rear end.
Not that i need it, i just want it...think it would look cool all lit up with the blue neon....got a 5 inch monster tach too.
But.......
Maybe I'm just getting old and / or simply wrong on this issue...... (and please correct me if I'm wrong!)
Doesn't this particular pillar gauge pod significantly obstruct your view out of a very important area (safety-wise) of the left windshield?
I've highlighted the area in red in the image below.
Perhaps it's just the angle at which the photo was taken, but in this view, this just seems to be a little on the dangerous side.
But.......
I have played with the placement we used to have it closer to the windshield THAT WAS A PROBLEM, So we went back to the drawing board and put it right on the inside of the pillar. It is perfect no obstructions and no complaints from any of the crossfire members that have purchased from us.
The C class and SLK gauges are in the works same goes with the pillar. I am in the process of making some crossfire pillars but as soon as they are done it is on to you guys. I am yet to find a car for mock up, in either class, so hopefully some kind salesman would let me do some test fitting on his lot. Also mercedes headlinner is much easier to get then chrysler headlinner. We are able to offer matching fabric and wrapping both pillars as well as painting to match interior and exterior.
The gauges are available to order here are both sets. Our website is in the works (still in mock up) they should be on there shortly.
1. Would you sell it a one gauge pod only, i only care about boost.
2. Any chance you can post these what they look like back lit
I believe the SRT have green illumination where the AMG's have amber.
and
3. Make a custom gauge for C55 owners where it's needle points from useless to worthless to keep them occupied while driving. (jk)
