I tried looking for a set of Eibach Springs for my C32 and cant find them anywhere, anyone know where I can get some? Also the best place I found were from evosport. http://www.evosport.com/product/default.aspx?catid=207
Is there a better place to get some H&R Sways?
Thanks in advance,
Bobby C.
Thanks in advance,
Bobby C.
you located?
Tirerack carries whole kits,how far are you dropping it?you will need matched shocks for the decrease in travel.Don't forget to get it aligned when done.
http://eibach.com/cgi-bin/htmlos.exe...74929000002024
or at their site they list online retailers.You will need a spring compressor,the good mb kind.Work safe
Thanks ohlordOriginally Posted by ohlord
you located?Tirerack carries whole kits,how far are you dropping it?you will need matched shocks for the decrease in travel.Don't forget to get it aligned when done.
I am located in Illinois, and I have a set of bilstein B8 sport shocks/struts sitting here waiting to be installed, but I want to install the springs and sways all at the same time. Tirerack says they dont have any for the C32 AMG, just different ones for different C-Class's. Do you or anyone else know which ones I need, or which set of springs for the C-Class would fit mine? I have 19's on there now. I read that a few C32 owners have this setup and they really like it(Eibach springs, bilstein B8 and H&R sways). Anyone have any opinions are answers to any of my questions? Thanks for your help!
cya
Ebay had everything you are looking for. When I was looking at buying springs there were several brands there, ie Tein, H&R, Eiibach, etc. all brand new at decent prices.
Will these work?
http://cgi.ebay.com/ebaymotors/EIBAC...spagenameZWD1V
bump, anybody know if those will work from ebay? above ^^
Never-mind, I emailed The guy about this and he said they will not work
Anyone know where I can get some Eibach Springs for my C32? I have the rest of the suspension here waiting to be installed, I just need some new springs. Someone PLEASE HELP!
.Anyone know where I can get some Eibach Springs for my C32? I have the rest of the suspension here waiting to be installed, I just need some new springs. Someone PLEASE HELP!
Any reason you're set on Eibach? Many others out there that are easy to find, ie H&R...
ExploreQuote:
The only reason I am set on Eibach is because I have read where other members have used this setup and really like it. Do you or anyone else think there will be much difference in my setup if I used another spring like H&R instead of Eibach(Originally Posted by SilverBulletAMG
ON SPRINGS,bilstein B8 and H&R sways)? How are the H&R's compared to the Eibach's? If anyone has any info to help me out I would really appreciate it. Thanks!I received this message from Eibach, it cant be right is it?
"Your car already has AMG spec Eibach Springs on it, so Eibach does not support an aftermarket spring for your car as the lowering would be minimal at best, if at all."
Currently Active Users (1)
