Code 3 spacers or LET spacers?
Old Nov 28, 2008 | 02:14 AM
Koru_Kinshi's Avatar
2018 E63S AMG, 2003 SLK 230 Sport, 2004 SL 600, 2006 SLK 55 AMG, 1998 E320 Wagon
Discuss?
Thinking about picking up the LET spacers private party. Are the Code 3s a better choice?
Old Nov 28, 2008 | 10:37 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Originally Posted by Koru_Kinshi
Discuss?
You'll get a mixed bag of opinions here regarding phenolic spacers. Some feel they help control IAT's, some feel they're worthless (and possibly detrimental, if they cause any boost leakage).
Most that think they're worthwhile tend to think the C3P spacers are the better option - they're quite a bit thicker, so their thermal insulating properties are much better. They also cost twice as much - last I saw, LET's were $45 MSRP (so, from a private party, presumably $30ish is the max you'd spend):
http://www.letmotorsports.com/c32.as...2&category=all
Old Nov 28, 2008 | 12:48 PM
ACRucrazy's Avatar
Crossfire SRT-6
Depends, do you want the spacer sometime soon, or would you like them aged like like a fine wine.
Old Nov 28, 2008 | 06:12 PM
TVT_DESIGN's Avatar
Former Vendor of MBWorld
Chrysler Crossfire
We offer spacers that go between the SC and the cylinder heads. It's a different approach then just seperating the two pieces of the intake manifold.
Link:http://www.tvtdesign.com/inc/sdetail/977
Old Nov 28, 2008 | 09:53 PM
SilverBulletAMG's Avatar
C32 AMG
Interesting. What are the specs on that setup? I have LET spacers on mine. May consider adding something along the lines of your product come spring....
Old Nov 29, 2008 | 05:17 PM
TVT_DESIGN's Avatar
Chrysler Crossfire
Our spacers are fairly simple to install, there's a write up on here somewhere.
Basically they actually remove the SC and the engine. The other spacers just move the top part of the intake manifold apart from the bottom part. This works well for testing with an Infrared sensor on the surface, but the air is still passing through the much hotter part to get in the cylinder head.
Both spacers have their place.
Old Nov 30, 2008 | 01:03 AM
C32 AMG
When I was asking about the "specs", I wasn't meaning the install, I meant performance/cooling gains documented with your spacers. The install seems fairly straight forward.
Old Dec 1, 2008 | 10:04 AM
p rossi's Avatar
c32, 190e 16v turbo
i have a set of LET spacers for sale never used for $50
