Op temperature for a C32
It seems when I'm cruising or accelerating gently, I run about 85-90 C. When I get heavy on the gas, the car goes up to 95.
That sound about right?
It's not acting weird, or making strange noises or anything...
01 In-car temperature sensor.
02 Outside temperature sensor.
03 Heater core temp, left.
04 Heater core temp, right.
05 Evaporator temperature sensor.
06 Engine coolant temperature. (most accurate)
07 Refrigerant pressure in bar (e.g. '4' is 4 bar).
08 Refrigerant temperature.
09 Not used.
10 Heater blower control voltage (normal 08-6.0, meaning .8 to 6 volts).
11 Emissions sensor voltage (to detect atmospheric gases and recirculate interior air).
12 Sun sensor voltage (to shift airflow in car).
20 Control current for auxiliary fan (electric fan on radiator, given in milliamps or mA).
21 Engine speed (x100).
22 Road speed (km/h or mph depending on installation).
23 Battery voltage at terminal 58d (as a percentage of total voltage, e.g. 99.0 = 99%).
24 Battery voltage (e.g. 12.8 = 12.8V).
40 Climate control software version.
41 Climate control hardware version.
