Check Engine Light
Old Dec 30, 2008 | 09:08 PM
EURO KNG's Avatar
03 C32 AMG
Check Engine Light
Well got my ecu back from LET today , so i installed it and everything was fine Took it for a drive and I could feel the difference right away , anyways I decided to get a oil change since i was due . Went to the same place i have been going for a while . The guy told me the check engine came on after he was done nd said come back if doesn't turn off in ten minutes.Im home now and its still on. So what should I do?? I dont wanna go to the dealer cause i don't want them to flash my ecu back to stock , thanks in advance.
Old Dec 30, 2008 | 09:42 PM
ohlord's Avatar
The dealer
will not reflash your ECU.
ECU mods are overrated unless you have done major work on the engine to require the new parameters.
Have you got a code reader in your tool box?
Read the code or codes and then post them so we can solve the issue.
Good code reader is only $39.Get one. Because if you keep messing with the ECU you will need it.
Old Dec 30, 2008 | 10:16 PM
EURO KNG's Avatar
03 C32 AMG
Where can I get one?.
Old Dec 30, 2008 | 10:51 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
You can also just go to an local independent Mercedes Mechanic and ask them how much to read the codes for you.
This place has them for $27 plus $7-$8 shipping or $21 for express.
http://www.alpha-bid.com/product18.html
Old Dec 30, 2008 | 10:54 PM
Chazz's Avatar
C32 ///AMG
Here's the one I use. Harbor Freight $45. Great investment.
http://www.harborfreight.com/cpi/cta...emnumber=94169
Old Dec 30, 2008 | 10:58 PM
ohlord's Avatar
Go to this link
http://www.harborfreight.com/cpi/cta...il_Store_ID=11
on the side bar for the stocton link enter part number 94169
print the price page for that scanner(I think I have sent so many members to the site that they raised the price to $44.99
and take it to the store,they will price match the internet price.
Plug it in the obd2 port under the dash,read the codes and post them.
Most likely a simple solution if it is not related to some value of a sensor change by the modified ECU.
Old Dec 30, 2008 | 11:00 PM
EURO KNG's Avatar
03 C32 AMG
Thanks , well i went into dyno mode to read what my oil level was at since thats the reason this stupid light came on got this
its blankkk????????
Old Dec 31, 2008 | 03:37 PM
EURO KNG's Avatar
03 C32 AMG
anybody know why its blank??
Old Dec 31, 2008 | 04:42 PM
ScottW911's Avatar
Super Moderator Alumni
a C32 AMG & S-Works Tarmac
Yes. You need to turn the igition on, without starting the car. Wait a couple of seconds and bam! you'll see your oil level.
Old Dec 31, 2008 | 05:11 PM
greasybenz's Avatar
W203 C32 AMG, W124 E300D
You could rent the OBD scanner at autozone for free. You just put down a deposit which they refund you when you return the scanner.
Old Dec 31, 2008 | 05:27 PM
1qikctr's Avatar
Merc power
Ditto go go go b4 they're close. GL!
Old Jan 4, 2009 | 03:00 AM
calimax's Avatar
RENNtech C32 AMG
Their the only ones with 24hr stores, albeit in ghetto locations....
Old Jan 4, 2009 | 10:07 AM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
amazon is also a good source for OBDII (OBD2) code readers - good prices too. GL!
