AMG Supercharger retro fit thread
Old 01-31-2009 | 12:32 PM
ali saklaoui's Avatar
C32AMG.335 e92 fbo.protomotive996 gt2
airmass meter substitute
Hello,i think that your car is a C55 equiped with an airmass meter.but the sc and the intake manifold of the E55k are equiped with a map sensor.so your ECU and wiring must be replaced.
Old 01-31-2009 | 03:25 PM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
I really dont have the answer to this question.
Old 02-01-2009 | 01:50 AM
OJwerks's Avatar
not stock.
im pretty sure that MAF stays there and a MAF clamp is used for the signal not to go out of wack when that blower begine to suck ALOT more air than what the car normally breaths
Old 02-09-2009 | 04:11 PM
hooleyboy's Avatar
C55,SL55,C63
Update
My car is now in the shop... So I'm stuck driving around in a old work minivan for a bit...
We ran into a crank pulley problem and were pondering ideas on how to get around it. Dyno-Comp was able to score a past customers car that had this mod done to it as well. So we will be able to spec out the custom crank pulley and have one made... so that a plus
So the project is officaly under way.
Old 02-09-2009 | 05:30 PM
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Congrats!! That's exciting news, hooleyboy... keep us posted
Old 02-09-2009 | 08:45 PM
crazeazn's Avatar
C55
whee! cant wait to see this done~
Old 02-09-2009 | 10:42 PM
  #32
MACHC5's Avatar
Veteran: Army
CLK63 Black, E350 Wagon, Supercharged Denali, Lotus Elise, Tesla Model 3 Dual-Motor.
Hi Guys,
I just picked up a Diamond Black 2006 C55 to replace my had since new 2005 C320 AWD daily driver.
What are the biggest things that help performance on these cars.?
Jim
Old 02-10-2009 | 12:40 AM
  #33
advans's Avatar
C55 ///AMG, 535xi
oh man...crazy project
Old 02-10-2009 | 01:08 AM
  #34
BLACKROOF C55's Avatar
C55 AMG
good luck on the project.. let us know the outcome...
Old 02-11-2009 | 03:33 PM
  #35
Gramma_Benz's Avatar
2002 C32, 2012 S550
80mm Throttlebody
Hey Hooleyboy,
Can you use one of these for your project?
https://mbworld.org/forums/engine-pe...-kit-sale.html
Old 02-11-2009 | 04:12 PM
  #36
jturkel's Avatar
02 C32 AMG
Originally Posted by MACHC5
Hi Guys,
Jim
........do some searching in the forum....tons of threads about this.
Old 02-11-2009 | 04:43 PM
  #37
hooleyboy's Avatar
C55,SL55,C63
Originally Posted by Gramma_Benz
Hey Hooleyboy,
I could... Right now I just want to get the car working right and then think about other mods down the road.
Old 02-11-2009 | 06:56 PM
  #38
lee7758's Avatar
Porsche 911 Carerra 4S
Cool!!!!!!!!
Old 02-11-2009 | 11:08 PM
  #39
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Hey Hooleyboy,
You will need a custom-made housing to fit on a C55
Old 02-11-2009 | 11:27 PM
  #40
hooleyboy's Avatar
C55,SL55,C63
The 80mm TB: If it fits on a 55k blower then it could be used in my project.
Old 02-11-2009 | 11:33 PM
  #41
Flame3g's Avatar
CLK500 SPORT
GL w/ project
Old 02-11-2009 | 11:43 PM
  #42
JG26_Irish's Avatar
SLK55 AMG, E320 BlueTec, ML350, (formerly) C32 AMG, MR2 Turbo, HD-FLH-FSE, BMW R100RS, Ducati M900
C55-Kompressor
Kudo's Hooley on the ambitious project. This is good stuff.
Am I missing something or is the car gonna wind up replicating the E55 engine set up in the C55? A lot of the detail items such as the Crank pulley might fit? Low compression turbo pistons or the stock pistons and rods from an E55 should work. The E uses the same head and block as the C and then added the kompressor. I would not be surprised to learn that the crank and rods are the same part number. But that info is outside my pay grade, lol.
Good luck with the project. If you think you had traction issues at the strip before, well just get ready.
Irish
Old 02-12-2009 | 12:07 AM
  #43
hooleyboy's Avatar
C55,SL55,C63
Irish
It will look just like the 55k motor, Other than running a custom made intake fitted with a MAFS rather than a Map sensor. We are going to have a custom crank pulley made to lower boost.
When its all said and done after the supercharger. I will take on another project to build the motor and trans. In about a years time it will be a decked out E55 in a C55 shell. To me thats a great combo, I will get the performance of a modded E55 with the size,weight, and nimbleness of the C55. Most of this stuff is a ways away though.
I plan on taking this m113 block to the limit. When this thing is done its going to be Barrett Jackson material.
Old 02-13-2009 | 06:19 PM
  #44
hooleyboy's Avatar
C55,SL55,C63
Update
The project is moving at a good pace. We just got an other person with the same type of mod to bring his car into the shop so we have an exact copy of what needs to be done. We also were able to spec out the crank pulley so that very good news.
Here is a list of parts needed so far
Guide pulley
Tensioner pulley
e55 thermostat
plenum gaskets
intake gaskets
lots of screws and blots
E55 fuel rail
E55 injectors (still dont have them yet)
E55 water pump with upper idler pulley
Custom Crank pulley
EGR by pass thingy
Modified Oil filter housing.
Heat exchanger (thanks Josh)
intercooler hoses and pump
belts
other Misc stuff
This is not an easy or cheap job, I'm married to this project So I'm in it to win it. Kleemann SC would be cheaper. However, I have the potential to run alot more boost down the road.
Here are some pics of the loner car and mine
Isnt this cover the ugliest think you have ever seen?
My Car
Custom Crank Pulley
MAFS with 55N/A Throttle body fitted to AMG SC
Old 02-13-2009 | 06:23 PM
  #45
aleksandar1099's Avatar
Mercedes
Guide pulley
Tensioner pulley
e55 thermostat
plenum gaskets
intake gaskets
E55 fuel rail
Custom Crank pulley
EGR by pass thingy
belts
other Misc stuff
Custom Crank pulley
My car
Looks awesome!
Old 02-13-2009 | 06:29 PM
  #46
TruTaing's Avatar
Moderator Alumni
w203 m112
Looks good! Glad to see/hear that there is real progress on this!
I noticed your valve covers are a bit leaky... maybe while everything is apart, ya should have those fixed? :x
Old 02-13-2009 | 06:39 PM
  #47
Dan Wang's Avatar
E320CDI, CLK55, and a Smart
Here's a thread about my CLK55 N/A being blown
https://mbworld.org/forums/clk55-amg...-my-clk55.html
Old 02-13-2009 | 06:41 PM
  #48
hooleyboy's Avatar
C55,SL55,C63
I just had them done so most of the grime is old
Old 02-13-2009 | 07:59 PM
  #49
TruTaing's Avatar
Moderator Alumni
w203 m112
awesome just lookin out
Old 02-13-2009 | 09:26 PM
  #50
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
It's going together, hooleyboy. Very cool!
Quick Reply: AMG Supercharger retro fit thread
