Feeler/WTB: SL 55 intake setup
Should've also mentioned, I'm looking for a Code 3 pulley or an ASP/Evosport kit as well. 2nd gen highly preferred. Don't want to be shredding belts. I was considering a 185, but I think I would need to seriously upgrade my cooling before I get that brash.
I upgraded to a carbon fiber intake a few years back but have been hanging on to the original in case I ever wanted to return the car to stock.
That includes the air boxes, tubes and the y splitter, right?
I think the biggest problem is that I have yet to see a before and after dyno with the 55 intake. So it is hard to compare this intake setup with others like the LET or the Code3 that have dynos showing gains.
Maybe the ultimate setup that would fit on the car would be the 55 hoses and 55 boxes with the stock splitter with the code3 on it? i think Newschpsy (spelling?) has some variation of this setup.
I went with the C3P b/c I wanted to go back to the factory look, nothing else.
Now Victor is hopefully enjoying my setup. The snorkels and the tabs have been modified to fit the C32 as good as OEM which is the biggest headache with this mod.
tabs are definitely annoying, though i was able to make the snorkels fit without modification with some "gentle persuasion" lol
Going to get another Dyno Tune by Jerry in March sometime prior to Drag season. I'll have Dyno sheet then.
I really think with my mods the SL55 setup is very beneficial for me...I really can't compare it to LET intake or C3P intake but Bret "Mustang281" has 360 WHP with 185mm, Jerry Tune and LET intake...so I'm hoping for that much.
The graph of the dyno also concerned me a little with the code 3 intake/pulley combo. You've seen it. It seems to make less power at low end, then tears off at the high end. Belt slip, maybe? Bad run?
