Anyone have the Code3 belt wrap kit installed?
Bob
https://mbworld.org/forums/c32-amg-c55-amg-w203/234573-turning-point-mercedes-tuning-performance-supercharger-pulley-17.html#post3318417
Thanks. I'll check it out.
As far as pulleys that it replaces, the belt wrap kit replaces the upper guide pulley, the middle idler pulley, and adds another pulley where the alternator pulley is. definitely a noticeable difference in feel. 7-10 whp may not make your car much faster on the street, but you can definitely feel a difference when driving.
yes i do!
Thanks! Great information.
pics can be seen here:
this picture shows the new wrap of the belt. the upper guide pulley is replaced as is the middle idler pulley. as you can see, the the upper guide pulley bracket is maintained.
this picture shows the location of the new pulley that is added in place of the alternator bolt
thanks!
You might've been thinking of ASP.
Jturkel - thanks for sharing the pics... definitely helps visualize the new set-up; lookin' good!
LET makes a 178? i didnt know that.....it is made to run with any 178 because they are all the same size (at least roughly). so i believe the 178 is made my ASP, Evosport, and Renntech. So any of those should work. The wrapkit is helped to reduce belt slip when running a stacked setup of a 178 crank pulley with code3's new midsize s/c pulley (not the one that came out like a while ago).
thanks!
PM me the price on the belt wrap kit and when you can have it available. If my pulley project works out, i'll definately need it.
I don't think it would cause significantly increased wear of accessories (i.e. no more than the other 178mm kits available). The larger the CP, the faster (and consequently, more often) it's turning those accessories... if the other pullies are not changed out to larger variants as well.
What I would be curious to know... if it causes any appreciable additional wear to the belt itself. That bend around the S/C pulley is pretty severe - the added benefit of reduced belt slip and increased responsiveness may be traded off with increased belt wear and more frequent replacements (IMHO, not really a big deal, it's an easy change and a $60 part). Time will tell... looks promising, however - nice to see new innovations as they pop up.
