Weird Buzzing Noise from Front Passenger-Side of Engine Bay
disregard that red circle that is in the picture. i circled in BLUE where the noise is coming from. i cannot exactly pinpoint it, but it is coming from that general idea. any ideas?
the air pump is the largest (the one circled in red)?
and then there is the emissions pump, which i'm guessing is the same thing as the smog pump? which one is that?
which one is the coolant pump?
grrr..
mike.....mine isn't making a whining noise though.....its like a low sounding bzzzzzzzzz noise. its weird. idk.
the noise your hearing is something else..probably what c32used said. I have hear it too when i put the key into the second position and not turn on the car.
that is reassuring that someone else has this noise. thanks
I heard that sound one time when I started the engine one morning. It went away after about 8 -12 seconds. That afternoon after work, I headed out to my car and fired it up. Same thing. I popped the hood and saw where it was coming from.
It was a hose with air blowing out, that came loose, leading to the alternator. Location; above the right headlamp next to the radiator.
Put it back on and never heard it again.
But, I did have an siren alarm go bad. It just went off on its own. The sound came from the right front passenger wheel well, between the brake and the firewall. Even after disconnecting the battery terminals, the sound kept going on and on. The weird part was that it didn't even sound loud enough to call attention.
Long story short, an MB shop replaced it and now, my car has a bird chirping sound when I lock and unlock the car with the remote. Cool I think.
I took the C32 out last night and when we stopped for dinner, I hear the same low frequency buzzing noise under the passenger side of the hood. It was buzzing after I shut off the engine, pulled the key and continued for several minutes after I locked the doors. On the way home it did not repeat. I took it out again to try to duplicate the sound but never hear it again.
So is it the smog/air pump (not a big deal) or the IC coolant pump? I know if the IC pump fails the SC will not engage right?
Irish
