Old vs New Piston Pics
Old 03-16-2009, 08:44 AM
indyjoe's Avatar
Originally Posted by AMGSC
As usual that is why I chose Vadim for my build. Knowledgable and trustworthy with NO BS and NO HYPE.
Thanks again and sorry I appear to be doubting you. I should bite my lip before I ever question you but your input sure is good sensible advice for me and these forum members who are doing extreme mods like Blackbenzz, Hooley, mb_c55_guy, Alumnar and a few others...
Not trying to be an a$$, but did you try to talk to vadim first about your concerns before posting this thread?
Old 03-16-2009, 01:13 PM
Vadim @ FD's Avatar
S600TT, R350
1. The NEW psiton has the oil ring located in the wrist pin cut out area. On stroker mustangs, this has lead to premature failure of the oil ring, usually around 10,000 miles. Vadium, have you addressed this issue?
We are not adding any stroke. I wanted to move down the rings so top can withstand more pressure.
Old 03-16-2009, 01:17 PM
MRAMG1's Avatar
S600, GL450, Audi A5 Cab
Thanks for the clarification
See yeah
Old 03-16-2009, 03:21 PM
msheredy's Avatar
MB
Sleeving an aluminum block on a street car is a 50/50 proposition.
Hey Vadim,
Aren't the majority of aluminum engines (including ours) produced today sleeved from the factory? I seem to only recall an early Buick [I think] V8 that Rover ended up purchasing that didn't use sleeves which wasn't a good design in the end.
Old 03-16-2009, 04:15 PM
MarcusF's Avatar
2002 CLK430
For a factory M112/M113, at no point does a block exist without the sleeves. One reason sleeving them is iffy, is because they’re not pressed in.
Mahle is the supplier of Mercedes-Benz Alusil sleeves. Alusil is a technology that's been in use for almost 100 years. To make an Alusil sleeve, a high-silicon content aluminum alloy sleeve is dipped in an acidic bath. The acidic bath etches away the aluminum on the outer surface, exposing a very hard, very long-wearing, silicon surface. The Mercedes-Benz M112/M113 press release says the sleeves are cast first, then, rather than being pressed into the block, the block is pressure cast around the sleeves. The outer 20% of the sleeve melts, bonding with the block. That's why the release says the sleeves are 'an integral cast-in part of the block'. So yes, the M112/M113 aluminum blocks are sleeved from the factory.
Old 03-16-2009, 04:39 PM
MarcusF's Avatar
2002 CLK430
The material is just a special coating so it can slide inside the Alusil cylinder walls. This coating is not in the original forged metal I believe.
Correct. Per the press kit, OE M112/M113 piston side surfaces are coated with an iron particle reinforced resin.
Old 03-16-2009, 04:57 PM
  #32
rockjock's Avatar
I DON'T COME HERE ANYMORE
Every 4 banger alum block I've owned has not had sleeves in them (and all were turbo'd from the factory)-and I had few issues with the block itself (wrist pins, rods, oil,turbo-ect).
Vadim-glad to see you take all this in stride-there have been some "interesting" comments made on here-I kinda look at tuners as this: Pick one-have faith/luck that they know more then you (that prob why you asked them to do the work) and trust it until it fails.
Props for a good build!
Old 03-16-2009, 05:08 PM
  #33
Former Vendor of MBWorld
hooleyboy's Avatar
C55,SL55,C63
We are hearing numbers of like 700hp you would think you want some added protection at such high HP.
Old 03-16-2009, 05:31 PM
  #34
rockjock's Avatar
I've tuned evo VIII and IX's (granted-its a 4g63 block) but even the new Evo X's are seeing mid 500's to the wheels on a new and "untested" alum block and head config running 25lbs of boost-and I've seen so many b16 civics running retarded amounts of boost (to the front wheels....I just dont get that) w/o sleeving
I think the set up that he is working on (yours too Holey) is safe w/o the sleeves-balance and blue'd-with the right supporting mods (fuel del., ect) you should be okay-my $0.02.
Old 03-17-2009, 02:06 AM
  #35
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Thanks Marcus. Very informative...
Old 03-17-2009, 02:16 AM
  #36
AMGSC's Avatar
Until??
Old 03-17-2009, 02:20 AM
  #37
AMGSC's Avatar
Hopefully with VRP/Powerchip behind the tuning, the Air-Fuel, Timing, etc...will be optimized to prevent detonation.
Old 04-06-2009, 01:48 PM
  #38
AMGSC's Avatar
A few more pics of work in progress.
Things are now picking up. Attached are B/4 pics. Entire engine block was rehoned and now the assembly process begins. We are in the final stages. After pics to follow in a day or two.
Transmission I believe is alread completed.
Attached Thumbnails Old vs New Piston Pics-dsc_1828.jpg   Old vs New Piston Pics-dsc_1826.jpg   Old vs New Piston Pics-dsc_1787.jpg
Old 04-06-2009, 03:21 PM
  #39
rockjock's Avatar
Until??
In my book...you're not trying if its not breaking
Good update-who did you have rehone the block? Just the head surface?
Looking good!
Old 04-08-2009, 09:35 AM
  #40
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
looks like its coming along nicely.
Old 04-14-2009, 08:13 PM
  #41
AMGSC's Avatar
Pics of Polished and Forged Rods
Things were moving slow but now picking up pace. Vadim should start full installation once the rod pins are in.
So does anyone know how polishing the rods can actually increase performance? Vadim tells me it makes the rods stronger and prevents cracks to form due to the high-load stress. It also supposedly makes reduces the friction of the rod movements.
Attached Thumbnails Old vs New Piston Pics-polished-rod1.bmp   Old vs New Piston Pics-all-rods.bmp
Old 05-02-2009, 02:34 PM
  #42
AMGSC's Avatar
Extreme Strenght Coated Pistons
Will easily withstand 30+psi of boost with the proper tuning.
Pic is located here.
Old 05-20-2009, 01:43 PM
  #43
AMGSC's Avatar
New Intercooler Pump > better than CM90
Here is what Vadim is replacing my CM30 with. It flows 4x better than the CM30 and is designed for coolant, not just water so it will last forever.
Old 05-20-2009, 01:51 PM
  #44
c32AMG-DTM's Avatar
2008 A8L, 2002 996TT X50, 2009 X5
Once the pump isn't a point of restriction, more flow doesn't equal any incremental gain AFAIK. That said, it sure looks beefy!
Is there an ETA for your car to be up and running again? Looking forward to your results.
  #45
AMGSC's Avatar
New Racing Control Arms
Further improvements to improve suspension, trackability and dragability....
Attached Thumbnails Old vs New Piston Pics-c55_new_control_arms.jpg   Old vs New Piston Pics-c55_control_arm_diagram.jpg
Old 05-20-2009, 02:00 PM
  #46
AMGSC's Avatar
New Pistons and Rehoned Cylinder Fitted
Here you can see a new Ross Racing Piston fitted inside the re-honed Cylinder Wall.
The car should be ready by end of this month but it still needs a 500 mile break-in period before the boost is applied and ECU re-tuned to support 20+psi.
Old 05-20-2009, 02:44 PM
  #47
rockjock's Avatar
Nice looking end links-keeping with the PSS9's-or upgrading those?
Old 05-20-2009, 03:05 PM
  #48
spr
spr's Avatar
Polishing the beams removes the casting flash and does strengthen the rod as it thereafter has uniform sheer strength etc.
Old 05-20-2009, 07:59 PM
  #49
AMGSC's Avatar
Per Vadim, these are not adjustable end-links from Code 3. They are control arms which cost me 10X more. Are you saying they are the same things as the ones Brandon is selling for $170? If so, I need to give him a call ASAP.
Edit: I just took a look at the diagram and it is clearly not adjustable end-links. These are stronger control arms that will allow the car to launch hard without breaking them.
Old 05-20-2009, 08:49 PM
  #50
NitrogenBalance's Avatar
none
It's possible you are changing all the contol arms from the dogbone OEM units. In that case cost would trump a single set of adjustable camber arms.
That motor sounds like it should be great!
I remember first seeing your car at HOP with Mario and Josh when you had it dyno'd post HPS. You probably don't remember taking me down the street for a taco break. Seems that alot has changed for the better, you unlucky gen2 guys. Sorry to bring back memories, but looking back what a story/project....
Quick Reply: Old vs New Piston Pics
