"Killer chiller" what do you think?
Old Apr 22, 2009 | 10:40 AM
hooleyboy's Avatar
Former Vendor of MBWorld
C55,SL55,C63
here is the link. Tell me what you think. Do you think it will work? I guess it runs off your A/C to cool down your IATs. I'm always a fan of trying something new.
http://www.killerchiller.com/index.html
Old Apr 22, 2009 | 11:24 AM
NitrogenBalance's Avatar
none
I'd try alky injection before going that route. It would drop IATs as good if not better than the AC thing. Its less complex also. You also wouldn't be running the AC all the time, which helps.
Old Apr 22, 2009 | 12:00 PM
SilverBulletAMG's Avatar
C32 AMG
I agree with NitrogenBalance. It's a cool idea running off the AC but there are better methods out there w/o having to run your AC.
Old Apr 22, 2009 | 01:13 PM
loungn14's Avatar
SPONSOR
From: Houston/ Austin /Toronto / UAE / Minneapolis / Orlando /Cincinnati
Eurocharged Performance ML63 and TT lambo
not worth it....
Old Apr 22, 2009 | 01:31 PM
SLK55R's Avatar
'10 Porsche Turbo PDK, 500e, GL450
can't use at drag strip
they don't allow the AC to be on when you are running.
Old Apr 22, 2009 | 01:47 PM
hooleyboy's Avatar
C55,SL55,C63
Its most likely not worth it, Plus I got a new H/E excharger heading my way soon, thanks Jake.
I cant sit tight for long without any mods to do.. So I'm going to put some cams in today and see what happens. They are just 55k cams nothing special. I will get a dyno for you win or loose.
Old Apr 22, 2009 | 02:08 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
Alky injection, then Cryo set up if you need more-but def alky injection-aqua mist set ups are quick quick installs (less then an hour on Evo's around here)-and are reliable too!
Old Apr 22, 2009 | 02:15 PM
alumar's Avatar
2019 E63s AMG
I found a limited increase with the Kleemann Cams ; flat to 15HP ;
I am having to fix a bad MAF sensor though so the car is out of commission atm... check out my A/F from this weekend's Dyno Day in Chicago ...
DIVING off the chart (Insanely rich mixture)
They car started throwing codes on the way up to chicago (thought it was bad gas) .. seems my MAF is way mis calibrated.. so ordered a new one just in case...
Previous Dyno was 441RWHP and 454RWTQ ... this was nearly 60hp off in chicago
Old Apr 22, 2009 | 03:23 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Who told you this
I have NEVER seen a track official in my life stick their head in anyones car to see if the A/C is running my friend.
Most tracks require you to run with the windows UP, so how would they know or better yet care.
I guess IF the evaporator was dripping badly they would think you have a leak, but come on what track checks cars this closely
To the OP, there is no such thing as a free lunch in the world of physics. The power you would gain from the cooler would be far less than the power consumed by the AC running.
Sorry guys, but nothing mankind has EVER built is 100% efficient. It’s called trying to build a perpetual motion machine, which does not exist guys.
See yeah
Old Apr 22, 2009 | 04:45 PM
ChicagoX's Avatar
W211 E55
Tech/start line officials don't stick their head in to check, but they are very attenuated to fluid leaks/spills.
One member here has this setup to cool their supplementary reservoir, with decent results. It's more of an in-between runs type of mod, rather than extended operation.
FWIW, the Kincaid guys are true hot-rodders and will work with you on custom apps.
Old Apr 22, 2009 | 08:59 PM
hooleyboy's Avatar
C55,SL55,C63
Your Boost looks good, But your air/Fuel is really fat. I had a problem with my MAF messing up my A/F. I would suggest rotating it and see what happens. It even could be a the dyno's o2 sensor is bad....
As for the numbers.. Thats all in the dyno. If it was a strait up Dyno-jet than a 60whp difference at these numbers is about right. 60hp difference is about 10% from a dyno-jet to a Dyno Dynamics.
As for getting cams done today. A call was put into Renntech about the cams and then Renntech put a call into Erhard Melcher the "M" in AMG and he said "Dont even waste your time putting E55 cams in place of the N/A cams." So nothing was done today.
Old Apr 22, 2009 | 11:26 PM
JG26_Irish's Avatar
SLK55 AMG, E320 BlueTec, ML350, (formerly) C32 AMG, MR2 Turbo, HD-FLH-FSE, BMW R100RS, Ducati M900
Chiller
Unless a larger AC compressor is installed, you will be limited by the amount of BTU cooling capacity is available from the AC system. That is relatively small and combined with the high volume of a V8 engine at full throttle, I would say This would be of dubious value. Plus you get the extra parasitic losses from the AC compressor.
The poster who suggested alky injection is on thre right track. But unless you live in freezing temps, water injection cools more than alcohol. If freezing out, mix just enough alcohol to keep from freezing. This is like a liquid intercooler plus it increases the mass flow thru the engine. It is a proven winner. A good intercooler is great cause it never runs dry but the water injection is a real good idea but only if you are running so much boost that detonation is a real threat. If the ECU is pulling timing, then this can increase power. Caution when injecting water or alcohol, make sure it is after the compressor not before it, lol.
Irish
Old Apr 23, 2009 | 11:53 AM
c32used's Avatar
LET C32 2002
+1
Old Apr 23, 2009 | 08:53 PM
whipplem104's Avatar
1990 300ce supercharged and intercooled
The best bet for the drag strip is to put a reservoir in the intercooler circuit with ice. You can run sub ambient temps. The superchiller is really a street use thing. The recharge time for the circuit takes to long. I have my own design on my car and it works fine for those warmer days to have some extra coolness on tap. It is not continuous though as there are not enough btu s.
Besides the a/c shuts off under full load on Mercedes.
Old Apr 23, 2009 | 09:57 PM
hooleyboy's Avatar
C55,SL55,C63
I have a totally independent intercooler/Heat exchanger system complete with reservoir.
Old May 4, 2009 | 12:56 PM
lightningfast7's Avatar
2005 E55
Ford lightning guys have run these for a while now with great results.. they are insulating the intercooler lines and some added a catch can to the drain tube for the **** track tech's.. 40 degree drop in post supercharger temps and one user averaged 3-4 tenths in the quarter on a high 12 second truck..
Old Nov 9, 2010 | 04:32 PM
blackbenzz's Avatar
haters crazy
bump
Old Nov 9, 2010 | 06:06 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Looks like a good idea to me.
Now remember guys the i/c cooling system has fluid in it that heats up over time or heat cycles...... so if you run AC to cool the i/c fluid down, then under WOT (wide open throttle) the AC compressor kicks off (normal for mustangs) you get your cake and eat it too.
Also when drag racing you can run the AC in the staging lanes to cool off the I/C fluid, then turn off the AC for the 1/4 mile run. But really if you are patient between 1/4 mile runs you can wait 1 hour or more between runs for everything to cool off.
