About ODPS setup ?
Old 02-12-2003, 08:27 AM
Shine's Avatar
Question About ODPS setup ?
Does anyone w/ODPS installation of C32AMG
change the feul setting to stage-2 or anythingelse other than the factory setup ?
Old 02-12-2003, 10:53 AM
pc527's Avatar
2005 B6 S4
Re: About ODPS setup ?
hi shine,
I have not change the fuel setting yet.
peter
Old 02-12-2003, 06:20 PM
Vadim @ evosport's Avatar
C32 AMG
Shine: We have not done any settings changes. After about 100 miles DME readjusts A/F to compensate for more boost.
Old 02-12-2003, 09:24 PM
Shine's Avatar
Thanks guys !
Would Evosport advice stage-2 setting could be better protection on lean ?
I'm not addressing on performance gains.
If the side effect is poor mpg, well,it's a dependent issue.
Old 02-13-2003, 03:49 AM
Mach430's Avatar
Shine,
There is no need to worry about running lean with our ODPS. As you can see from Vadim's dyno's, the DME perfectly adapts, and does not run lean.
Old 02-13-2003, 05:28 AM
Shine's Avatar
Thumbs up
Looks great ! Evosport.
How's the need for step colder plug (NGK5) ?
it shows the best curve (Red),though the green curve got best spikes.
Old 02-13-2003, 11:09 AM
C32 AMG
Shine: We have tried going with NGK5 plug, but it wears out very quickly. In about 8K they start to misfire, so we are back to stock Iridiums with 0.035'' gap vs. stock 0.039''.
Old 02-13-2003, 07:17 PM
Shine's Avatar
Smile
Do all these notes cover in the written instruction ?
All adjustment & check required after hardware installation.
Thanks.
Old 02-14-2003, 01:39 AM
C32 AMG
Yes, the instructions will cover a complete install and should be ready next week. I have a couple of schematics to complete.
Old 02-14-2003, 03:06 AM
Shine's Avatar
Thanks !
I'd like to say "Take it easy" but members here are expecting
them badly.
Old 02-14-2003, 03:56 AM
amgme's Avatar
07 SL550; C32 (sold)
if you go in for service b, will mb replace the plugs w/ the stock plugs? what if that happens? will there be any negative effect if they replace it w/ the .039 plug?
Old 02-14-2003, 12:00 PM
C32 AMG
No, we gaped stock plugs down as an extra insurance against possible misfires in case of getting some bad gas.
But it is not a situation where it misfires at 39 gap and is OK at 35.
Old 02-14-2003, 12:39 PM
Mach430's Avatar
Thanks !
them badly.
Your kits will be shipping next week.
Old 02-14-2003, 04:58 PM
Pierre32///AMG's Avatar
Porsche Turbo Stage 4, Cayenne S ... gone C43, C32, ML55 & Ducati 999.
Shine: Be ready to kick some asses over there!!!
Old 02-14-2003, 05:12 PM
Carl AMG's Avatar
2002 C32 AMG Orion Blue Charcoal/Blue
Pictures?
Does anyone have pictures that show where the IC resevoir is and how it looks?
Old 02-14-2003, 06:28 PM
C32 AMG
I wil doing R&D updates over this weekend. Pictures of ODPS and headers will follow. Please stay tuned.
Old 02-14-2003, 08:50 PM
Shine's Avatar
You bet !
Old 02-20-2003, 07:37 AM
Shine's Avatar
Question
Vadim :
Do u recommend K&N or BMC hi-flow filters to match the ODPS ?
Thanks !
Old 02-20-2003, 10:35 AM
C32 AMG
Actually neither. On C32 air enters into the air box from the side. Stock paper element when sitting inside the box is blocks about 1/3 of that side opening. However, being made out of paper, ther e is still some flow going through that blocked part. I will post some pixs that will explain it better.
When we tested ITG and K&N filters they both lost power. The reason is the edges of the filters are soild. So when they are placed inside the box, they end up reducing cross section of the side opening and limiting the flow. ITG lost as much as 14HP due to this.
We are working with a local company that can make gauze filters, similar to K&N and others, that will not have a solid edge, thus flowing more air. When combined with better rear splitter design, there is about 3-5HP on a stock car.
Old 02-20-2003, 11:24 AM
Carl AMG's Avatar
Interesting
I recently put some K&N's (the model number for the C32 that was only recently introduced) in my car but haven't even had a chance to drive the car since the installation so I do understand what you saying about the air coming into the air filter box from the side. I know what you are saying about the stock paper element hanging down below the filter frame as well.
What I don't understand is the issue about the filter frame as they are solid rubber on the stock and K&N but, if I recall correctly, they both sit on top of the air filter box rim. The K&N also doesn't have any filter hanging below the frame like the stock one does so the filtering element wouldn't be blocking the side inlet.
I'll look at this issue more closely next time I clean the filters. Maybe there is some trimming of the bottom of the filter frame could address the issue. By the way, the stock filters definitely don't look like they are designed to flow a lot of air!
Old 02-20-2003, 07:31 PM
my401's Avatar
c32
air filters
This info is most interesting. I hope someone can Clear the Air.
(no pun intended). I have the same concern about air flow and power.
Old 02-20-2003, 07:54 PM
Carl AMG's Avatar
my401...
You have plenty of power already!!! You must stop this quest for power before your wife finds out. LOL
Old 02-21-2003, 10:03 AM
my401's Avatar
c32
air and power
You are right. The problem is living in the same city as Cannon and his E55k. Every corner I turn, every time I go to the Track, every woman I meet: HE'S BACK!!! I'm thinking of letting the air out of all his tires
Old 02-21-2003, 02:00 PM
rage2's Avatar
C63 BS, GLA45
Interesting, because I got totally different results than you with the ITG filters. I tested on a stock SLK 32 though (not pulley'd motor). This was tested on the same day, within minutes of each other. 5 runs were made with 60 second breaks between for stock config and ITG filter config. The highest peak HP run was used for both stock and the ITG filters (3rd for stock, 5th for ITG if I remember right).
Here's the excel sheet with the 2 dyno runs, as well as HP and TQ change between the 2.
http://www.virgeweb.com/rage2/misc/ITGSLK32.xls
Old 02-21-2003, 03:15 PM
SiLvaC32's Avatar
C32
oh wow~ that looks like GOOD results by changing the air filter. ITG filters... if they can add 8HP and 7lbs of torque... i am game!
Jerry
Quick Reply: About ODPS setup ?
