C32 headlight w/ headlight washer
Old Jun 19, 2009 | 07:09 AM
kattanah's Avatar
W203
I just bought a 2002 C32 with a headlight washer and I am not sure whether my headlights are xenon or not. Does having the washer mean that my headlights are xenon?
I am asking this question cause I am trying to replace my headlights with the 05-06 clear headlights.
If one of you guys has a C32 w/ a washer and replaced his headlights to the clear version would help me here, I would really appreciate it.
Old Jun 19, 2009 | 07:32 AM
Glyn M Ruck's Avatar
Super Moderator
American C32's are speced differently to SA where they are full house. If your car has the washers & auto leveling, which were part of the kit then likely it has Xenon headlights with frosted covers. Your ideal move is to fit OE Bi Xenon lights because you have all the kit in place to do this properly. Look for level sensors on RHS front sway bar and RHS rear axle/lower wishbone with a connector rod. I believe that FrankW must have done this. The move to standard clears would be a move backwards in all but looks. This is the kit you need - wish it was a C32
Old Jun 19, 2009 | 08:16 AM
moosejaw's Avatar
none
The (Premium?) package sold with the 2002 C32 was headlight washers, auto levelling, and frosty xenons. In 2003 this was upgraded to Bix. This was available on all c-class cars incl the coupe.
I am not aware if US cars had the stand alone option of headlight washers.
Old Jun 21, 2009 | 02:24 PM
kattanah's Avatar
W203
Thanks guys, its my second post in this forum and its my first thread, so bear with me a bit
Do you guys recommend a specific after market clear headlight that supports my xenon lights?
Old Jun 21, 2009 | 03:07 PM
Super Moderator
If you don't want to go OE then go Depo aftermarket look alikes. Not as good as the real thing but a reasonable compromise.
Old Jun 21, 2009 | 03:16 PM
kattanah's Avatar
W203
Will the stock xenon light fit the Depo?
Old Jun 21, 2009 | 03:48 PM
moosejaw's Avatar
none
i dont think so
the bulbs are diiferent and so are the housings
I would look for a Bix kit.
Contact Steve at MbenzNL
Old Jun 21, 2009 | 04:17 PM
kattanah's Avatar
W203
so far this is the only lens i found that can be modified to fit a factory xenon headlights
http://cgi.ebay.com/ebaymotors/2001-...ht_6559wt_1178
Old Jun 21, 2009 | 04:58 PM
Super Moderator
Those are Depo's Note you need to order with Zenon upgrade. Is going for the genuine article more than you want to spend?
Old Jun 21, 2009 | 05:51 PM
kattanah's Avatar
W203
I wanna keep it bellow the $700
Old Jun 21, 2009 | 06:46 PM
moosejaw's Avatar
none
to be honest you may ne able to get a set of bix for a little more
I would save up the dough
Remember you could always offload your old ones for a couple hundred bucks
Old Jun 22, 2009 | 06:01 AM
Super Moderator
I think Steve from MBenzNL does them at about $1100 fully installed & set up on one of his trips to the West or East coast. See what he would charge you if you do all the grunt work.
The Depo's are OK but they don't focus down tight or have the clean cut off of the OE lights.
