Computer read out tells me this: Lower Oil Level...
Old Jun 22, 2009 | 04:40 AM
SGTzAMG's Avatar
Veteran: Army
02 C32 AMG, 05 SL55 AMG, 09 SL63 AMG, 14 E350, '18 G550, 92 300ZX & 15' GL63 AMG
Question Computer read out tells me this: Lower Oil Level...
this malfunction pops out when i drive the benz for a while...and i just ignore it, becasue after a while the car has been sitting for a while and start it back up, the malfunction doesnt appear...should i ignore it, or should i really lower the engine oil level? help out please!
P.S. just went out and checked oil level outside, and the car has been sitting out for almost 4 hours now, it says that oil level is ok...so i dunno?
Old Jun 22, 2009 | 07:43 AM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
How are you checking the oil level? Dipstick? Dyno mode? You may also have a bad oil level sensor.
Old Jun 22, 2009 | 09:02 AM
moosejaw's Avatar
none
These cars are known to drink 1/2 to a full qrt of oil between oil changes.
How many miles to your next service?
If ur handy do the oil change yourself (i'm assuming since you have a Fairlady Z?)..... be sure to remove the skid plate housing and there are two plugs that drain the oil. Do a search for oil change DIY and you'll come across it.
Afterwards reset the computer (another search)
Old Jun 22, 2009 | 02:11 PM
SGTzAMG's Avatar
Veteran: Army
i see i see, the Service B is due in 9600 miles...i just got the car last friday so im still very new to the AMG...sweet ride though!
THANKS Moose! btw, your AMG looks clean! im still loooking around on what mods there are to do on the C32's...but now...i think the main ones are the obvious 19's and lowering springs..
is your AMG lowered? i like the stance of your car man!
and RX-7! thats what im talking about! :-)
Old Jun 22, 2009 | 02:42 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
go to autozone and get some mobil1 0w-40...
Old Jun 22, 2009 | 03:10 PM
boohooramblers's Avatar
Not an AMG :(
Originally Posted by MiZterC32AMG
this malfunction pops out when i drive the benz for a while...and i just ignore it, becasue after a while the car has been sitting for a while and start it back up, the malfunction doesnt appear...should i ignore it, or should i really lower the engine oil level? help out please!....
You do NOT want to be driving the car around with too much oil in the motor. Do NOT ignore it.
If a warning light is appearing telling you to lower your oil level, then you should assume that the computer is correct (until such point that you know otherwise).
....P.S. just went out and checked oil level outside, and the car has been sitting out for almost 4 hours now, it says that oil level is ok...so i dunno?
The appropriate way to measure the oil level is to have oil up to normal operating temperature and then to measure it on a flat surface no less than 5 minutes after turning the motor off. [Page 141 of the user manual]
This is because:
  • You need to let the oil return to the oil pan.
  • You need to allow proper thermal expansion of the oil in order to get an accurate level.
4 hours is far too long to wait to obtain an accurate oil level reading after turning off the engine.
i see i see, the Service B is due in 9600 miles...i just got the car last friday so im still very new to the AMG...sweet ride though!....
If 9,600 miles are remaining according to the FSS, then it is probable that somebody changed the oil a relatively short time ago. Did a dealership change the oil? Even it it was the dealership, it is entirely possible that somebody put a little too much oil into the motor.
Old Jun 22, 2009 | 06:01 PM
moosejaw's Avatar
none
I agree with the professor
Old Jun 22, 2009 | 11:18 PM
SGTzAMG's Avatar
Veteran: Army
WOW! okies! will do! Thanks guys! awesome response!
Old Jun 22, 2009 | 11:24 PM
aho's Avatar
aho
03 C32 AMG
I love how friendly and informative this forum is. I love you guys... LOL
