greenfilter air cleaner fell apart
Old 06-23-2009, 12:03 AM
mikekuriger's Avatar
2010 C63
I've had greenfilter air filters on my c55 for about a year. A couple of days ago I was driving my kids to school and the car just dies. It would not start and after resetting the ECU as a last ditch effort, it started but ran terribly. I managed to get it to the dealer where they discovered the MAF sensor was bad. Then we discovered that the green air filters had broken apart and pieces of that black gooey rubber that they are made of was all over the inside of my intake. I've never seen that happen before with a K&N, as they are made of actual rubber and the GreenFilter was made of a really really soft gooey rubber. I'm not sure how long these things have been torn apart like this but I just replaced them with K&N filters like the dealer recommended.
I'm curious if anyone else had had problems with air filters. Did I perhaps install them wrong or something?
Thanks,
Mike
Old 06-23-2009, 12:06 AM
jturkel's Avatar
02 C32 AMG
yes. this has happened MANY times with green filters. There is something wrong with them. use K&N. NO ONE has had problems with K&Ns falling apart or anything (as long as you dont put the filters in sopping wet after cleaning and recharging).
Old 06-23-2009, 12:07 AM
Former Vendor of MBWorld
hooleyboy's Avatar
C55,SL55,C63
Dude I would call Green right way. Thats some BS. if you ask me. Sadly though Greens have been known to do this.
Old 06-23-2009, 12:08 AM
JonMBZ's Avatar
06 C55, 09 E350
I wouldn't use any high flow filters your just allowing more dirt to go into the engine. I can't imagine a filter falling apart though pretty scary.
Old 06-23-2009, 12:11 AM
advans's Avatar
C55 ///AMG, 535xi
I think you should just replace it with the OEM filters.
2010 C63
I was thinking I would call greenfilters, but after thinking about it I doubt they will do anything about it. I was glad that the dealer recommended the K&N.
Old 06-23-2009, 12:13 AM
jturkel's Avatar
02 C32 AMG
https://mbworld.org/forums/c32-amg-c...lkthrough.html
post 11
sillverbulletAMG (trevor) is doing something about it. contact him.
Old 06-23-2009, 12:57 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
Sorry to hear that.
It happened to me last year as well and I was lucky to find out about the problem early....
If I were you, I would def contact the company and raise hell.. They will stand behind their products. Thers no doubt about that. They sent me a new replacement for free.. However, I had to pay for international s/h charges
If the filter caused further damages to your car, you should get an reimbursement for the repair.
So far, my new filters are problem free.. But I always keep my OEM filters in the trunk just in case..
Good luck n keep us posted.
Old 06-23-2009, 01:17 AM
AMGC43C55's Avatar
99C43 05C55 06slk55
your MAF went bad do to the filter but what about your engine cyl walls and rings?
Old 06-23-2009, 01:25 AM
jturkel's Avatar
02 C32 AMG
might wanna change your oil too actually if you are missing bits of the filter....
Old 06-23-2009, 01:34 AM
1Lop2K5C's Avatar
C63
Can't go wrong with OEM AMG filter 113-094-00-04. Thinner than the regular M113 engine filter.
Old 06-23-2009, 07:52 AM
C43AMG's Avatar
98 Black C43 , 08' ML320 CDI ,11 E63
.....I can't believe I am reading this.
Old 06-23-2009, 07:58 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
its really common with green filters..almost all of them have fallen apart at one point for the owner. They will replace them, just give them a call. I would just go with the K & N's or oem. I've had K & N's on my car for over a yr and all my other past cars with no problems. A lot of dealerships sell K & N's as a performance accessory at there part shops.
There's not a big difference between the K & N's and oem. You do notice a slightly better off the line throttle response with the K & N's.
Old 06-23-2009, 12:56 PM
14cue's Avatar
05 C55
I've had K&N in mine for 3-4 years (same one!). About a month ago I finally replaced them, they were filthybut they held up and did the job. I've considered going Green but I have since gone back to stock. It doesn't effect performance anyway. Stock FTW.
Old 06-23-2009, 02:03 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
I think the stockers are best too-but the idea behind K+N's is that with some maint-you really dont have to buy another filter ever again-
I clean mine every 10k or so-havent had any issues ever with these on any cars (and I monitor many paramiters all the time to check MAP, MAF, IAT, ect ect)
sorry to hear about the Greens!
Old 06-23-2009, 03:16 PM
AJBoost's Avatar
C32 AMG, Trans Am, Lincoln Navigator, E36 325i
That really sucks! The problem with any aftermarket filter is while they flow more, they usually also have their share of issues. Unless you're searching for every single last ounce of power, I suggest just sticking with oem units. Good luck to you.
Albert Hernandez.
Old 06-23-2009, 04:05 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
My Green Filters crapped out on me , too in less than a year.
The problem is not the filter material itself but the rubber molded flanges. They turn soft then come off the filter housing that hold them in place because of air being sucked in. When I opened my filter housing, half the length of filters just caved in and the rubber flanges were all melted out of shape.
I'm surprised this company has not fully and publicly acknowledged this serious flaw. Replacing for free the filters with the same inferior product does not do anything to improve their product.
Stick with K&Ns. I've never had a problem with them on both my MBZs.
Old 06-23-2009, 08:48 PM
BigBodyBenzC240's Avatar
...a panty dropper...
Looks like I am going to buy some K&N filters soon before my green filters crap out on me. Sorry to hear about this!!!
Old 06-23-2009, 09:00 PM
hcetzneb's Avatar
2004 Ran SRT-10,2007 S550,2016 E400c
I would just stick with the factory paper filters.. The K&N filters are great filters but the oil on them cause premature maf failure. Because the maf is a hot wire sensor the oil can give fase reading and mess up the sensor.. all the major tuning companys suggest factory filters Kleenman , Renntech, ect....
Old 06-23-2009, 09:25 PM
60n5pt1's Avatar
C32s don't have MAF
C32s don't have MAF sensors.
Old 06-23-2009, 10:11 PM
CLS, SLK, ETC
C55 does ...
Green said they fixed the issue with newer filters (back in 07)...Mine (replacement) are problem free so far..I'm going to clean it again with the cleaner kit and hopefully, **** won't crap out like it did before..
Old 06-24-2009, 03:39 AM
jturkel's Avatar
02 C32 AMG
See, I'm going to be completely honest. It is not easy to mess this up. ALL you have to do is follow the directions and make sure it is relatively dry before putting back in the car. I've done this SOOO many times on multiple cars
After reoil, just let sit for a while. Heck, I actually put mine in the oven for about an hour and it was perfect. Or just let them sit out over night. The filters really have to be dripping in oil to cause MAF sensor problems.
correct! MAP sensors it is!
Originally Posted by Quicktwinturbo
C55 does ...
Correct too!
Old 06-24-2009, 04:22 AM
TemjinX2's Avatar
agreed, most if not all bad maf sensors from k & N's are from human error. Because some people think drenching the filter in oil will filter better...
Old 06-25-2009, 12:57 AM
hkycoldrct's Avatar
2002 C32 ///AMG
Call Green and they will send you out a replacement set. I spoke with one of their engineers a couple years ago and they had a production run that had bad gasketing on them. I would suspect this was MOST of the Green filters out there for the C32 since there are only so many of them out there. The issue has supposedly been corrected.
Old 06-25-2009, 01:20 AM
AMS Performance's Avatar
AMG
K&N is the most trusted name in performance filters for a reason. Stick with K&N.
Quick Reply: greenfilter air cleaner fell apart
