Connector for IC Pump
Old Jul 20, 2009 | 09:40 AM
fergsc32's Avatar
2011 c63 AMG
I will be replacing the pump this week but was wondering about the connector. The ebay pumps look like you need to go get a connector
I saw this http://www.siliconeintakes.com/produ...oducts_id=1001
Is that the way to go??
Old Jul 20, 2009 | 11:28 AM
Zeppelin's Avatar
C32
That is the way to go if you want the cleanest and most secure connection without using the OEM pump.
Old Jul 20, 2009 | 03:45 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
I'd go with the Johnson CM30. My Ford Lightning bosch pump went out just as quickly as the OEMs.
Old Jul 20, 2009 | 06:31 PM
320 dreamer's Avatar
2003 porsche 996 turbo
either the ford lightning pump or the cm30 will need a electrical connector. i just tore the old pump apart and reused the oem connector
Old Jul 20, 2009 | 08:22 PM
fergsc32's Avatar
2011 c63 AMG
my assumption then is that I would need to cut off the original plug, and then splice the wires onto the plug wires in the pic from the link..seems pretty straight forward and a better option than soldering
Old Jul 21, 2009 | 12:19 PM
02C32guy's Avatar
2005 E55
Yeah, that's what I did and it worked perfect and was very simple. I use the connector from the Bosch pump and just spliced it to the wires with butt connectors. Easy peezy...
Old Jul 21, 2009 | 12:56 PM
im a little more **** than most! i tore the old pump apart as you can see the original pump connector goes inside the housing. using a solder gun i removed the oem plug and capacitor and wired it to the cm30 with solder and heat shrink tape. this provides a oem connection with a watertite seal and a nice look
Old Jul 21, 2009 | 04:30 PM
fergsc32's Avatar
2011 c63 AMG
Just ordered,, better I think than the ebay once since I would need to get the connector from ford anyway. Total with 2 day shipping was 125 bucks.
Cant wait to install. I have only had the car 2 weeks so I dont know what it is like yet to drive without this hinderence
Old Jul 21, 2009 | 05:26 PM
just remember when your new bosch pump goes bad we warned you!!
