Rear Cross Drilled
Old Jul 20, 2009 | 07:47 PM
fergsc32's Avatar
2011 c63 AMG
Rear Cross Drilled
For appearance sake..Has anyone put cross drilled rotors on the rear and if so.. what is the best resource for them?
Old Jul 20, 2009 | 08:22 PM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
I havent received the rotors yet, but, I went thru brakeperformance.com. You have many choices...R1 concepts, brakeperformance, Zimmerman,...alot on e-bay. Many folks have done it.
Old Jul 20, 2009 | 09:44 PM
OverDrive's Avatar
Volvo
I have, Wish i did it to the front, but i just had them replace with oem, so it looks a little odd with the back crossdrilled and slotted, and the fronts arnt, there just slotted
Old Jul 20, 2009 | 10:01 PM
fergsc32's Avatar
2011 c63 AMG
The fronts ARE cross drilled OEM....
c32used's Avatar
LET C32 2002
I have both R&F crossed drilled and slotted hopefully soon it'll be installed
Old Jul 20, 2009 | 10:18 PM
moosejaw's Avatar
none
i got mine OEM from a SLK55
Actually C55asleep(RIP) hooked me up with his old set.
Old Jul 20, 2009 | 10:36 PM
60n5pt1's Avatar
2002 C32 1987 190E 2.3 334K miles and going
Would these be the OC brakes?
Old Jul 21, 2009 | 10:53 AM
RicksC55AMG's Avatar
E55 AMG - C55 AMG
Does anyone know where to get Calipers and Rotors for the Rear on a C55? Looking to get the same AMG calipers I have on the front..
Old Jul 21, 2009 | 11:09 AM
moosejaw's Avatar
none
Dealer is your best bet! esp if you have a buddy in parts dept!
Old Jul 21, 2009 | 11:39 AM
mdncn2762's Avatar
Dont forget the 60/40 rule. I would do 6 pot up front, 4 in rear. Or 4 pot in front, 2 in rear, which is stock, and so on. Most of the braking is done with the front.
Old Jul 21, 2009 | 03:25 PM
WaveyKat's Avatar
Something Slow
i had C32 4 pot front & CLK55 4Pot Rear never had a problem stopping!
Old Jul 21, 2009 | 07:58 PM
moosejaw's Avatar
none
about to say the average lay men isnt going to notice
when u have the dough, spring for the 6pot dumplings later
Old Jul 21, 2009 | 09:00 PM
SoCalC55's Avatar
2019 AMG C43
Are there any problems that can arise from running the same setup front and back(ie: install a set of stock front breaks/rotors on the rear)
So you kept the front stock and installed the rear break system from a clk55? Was it a direct fit or did you have to modify anything
Old Jul 21, 2009 | 10:52 PM
moosejaw's Avatar
none
From what I have seen you do have to trim the rear brake hub to take the new caliper.
Old Jul 21, 2009 | 11:03 PM
WaveyKat's Avatar
Something Slow
you have to Trim a small piece of Metal Off the "Rotor Shield" and yes i kept the C32 Front and added the CLK Rear..
Old Jul 22, 2009 | 12:06 AM
moosejaw's Avatar
none
Corrected I meant the dust shield, dont cut your brake hub.
Forgive me as I'm still shocked over spending $10 for that POS film, Bruno
Old Jul 31, 2009 | 12:14 PM
chuckactor's Avatar
2002 C32 AMG
I just installed a pair of drilled SL500 Silver Arrow rear rotors on my C32 last weekend. The ones I bought are Zimmermans. There are two differences between the Silver Arrow rear rotors and the C32 rear rotors.
1) The Silver Arrow rotors are drilled
2) The SL500 uses 14mm lug bolts as opposed to the C32 which uses 12mm lug bolts.
I will post a picture later. I was worried about this at first but figured I'd run them for a bit before I commented. Even on the stock rear rotors the lug bolt holes in rotor are larger than the lug bolts themselves. The torx screw that attaches the rotor ensures the holes in the rotor are concentric with the holes in the hub to allow you to easily install and remove the wheel etc. In the stock C32 rotors there is enough clearnace between the holes in the rotor to the lug bolts for me to assume the rotor is not bearing against the lug bolts during braking. If it was the case, the torx screw would be sheared the minute you jammed on the brakes.
I'll post a pic tonight and show you what I mean.
Old Jul 31, 2009 | 12:42 PM
fergsc32's Avatar
2011 c63 AMG
Thanks for this website... they have a sale right now and i just bought the pair of rear crossdrilled and slotted, and ceramic pads all for 170.00 shipped.
Old Jul 31, 2009 | 12:56 PM
1qikctr's Avatar
Merc power
I went with some R1 rear drilled rotors. They are great.
Old Jul 31, 2009 | 05:35 PM
moosejaw's Avatar
none
They completely suck.
They used to sell dimpled rotors exclusively which are fake x drilled rotors. I thought they were real. They adverstised them as x drilled with a little tiny disclaimer that they were dimpled. I returned them with shipping and 20% stocking on my dime. I filed a dispute with paypal citing deceptive advertising and bait and switch.
In the middle of the claim they statred to sell real x drilled rotors. They update their website and told Paypal I had the option to buy real x drilled rotorrs, which made me look like an idiot. They are a bunch of real dicks and i wouldnt buy any of their products again.
