Plugs/Wires question
With your mods, it's suggested to go with a colder plug such as an IK22, I've also heard that it's best to gap at around .034. And if you have extra $$$, might as well do the wire at the same time. Probably won't make a huge difference, but people DO write that things runs smoother when they replace both. I used to have a Code3 Pulley and just got IK20's.
go with 8.5mm Magnecor Wires
for plugs, either a step colder with the IK22's or the step colder version of the NGK IXs (i forget what the number is for that one)
gap them at .034
only the 55 splitter? you should consider completing the 55 setup with the respective airboxes and hoses, as if i remember correctly, the 55 splitter by itself won't do much. just an IMO.
gap them at .034
Thanks guys, i am running now with the ik20's but I think i want to go one step colder with KV85 and i'll see the difference.
Just because i love the view of the OEM engine cover I didn't go with the 55 airboxes plus here in Lebanon it's hard to get them.
Is there a noticible difference with the 55 air boxes?
Do i need a retune if I will go with them?
and i think you can make the SL55 cover fit (with minor trimming) if you want
idk what the first one is, but the second number you listed looks like the NGX IXs (or might be the same) i purchased. just make sure it is one heat range colder before purchasing if thats you want. its either bkr 6 or bkr7 i think
2003 porsche 996 turbo
i have a sl55 setup for sale. if you want to pay the shipping i will look into shipping https://mbworld.org/forums/engine-pe...ml#post3647342
http://www.needswings.com/Products.a...E-1CD09899D261
I also just posted my own step by step for the change of the plugs.. just search my posts
