How many miles does your C32/C55 have?
Its been an awesome car really reliable, I replaced:
gas pedal assembly,crank sensor,plugs,and intercooler pump,thats all the major stuff besides the usual brakes, oil changes,tires and a battery
Replaced IC pump at 40K
Minor sensor that made the check engine light go on.
Replaced cup holder
AC issue small leak
Convenience sensor replaced
Recently re-flashed the software with Singh Autosport ECU tune, it seems a little quicker than before. The dealership updated my software and erased my old tune...
Supercharger
2 sets of heated seats
Seat computers (driver and passenger)
Steering colum adjustment acuator
All doors are rusted through. Looks horrible.
Control arms
"Sam" computer
Crank position sensor
Three or sets of brakes
8 sets of tires
Sunroof control unit
A brake switch for the BAS system
A transmission sensor that would send the car into limp-home mode on cold days
And a lot of stuff I can't recall
The car really is not reliable or well engineered.
Supercharger
Control arms
"Sam" computer
8 sets of tires
i think the rust issue might be his location. he's probably located somewhere in the rust belt where they use a lot of salt. but in his defense the paint job on the w203 do suck...the quality was worst then my 04 civic.
The paint chips really easily for a premium car. It almost seem like they stopped short a few coats to save a few cents.
Nah, I am not buying any of it, Vic's was abuse, pure and simple
I don't know, the paint job on my 04 is actually not too bad and my ML 55 has a real nice paint job. I just checked the inside qtrs and underneath the
car and much of it is galvanized, so perhaps the older C32s suffered this rust problem. Rust can be as much as a maintenance issue as a build quality issue. I've seen older Honda Accords (notorious for rear wheel well rust) in Chicago in beautiful shape that were probably washed weekly in the winter to avoid the rust issues. You can't let any car sit for weeks at a time with salt caked on it or in the wheel wells. Its that corrosive. I wash at least once a week, even if its thru the local Shell Gas station wash.
I am the second owner and it had 12,500 when I picked it up. I work a the dealer (Mercedes) now that's 20 miles one-way and I will be working at the new one that's a half-mile away.
radiator,
torque converter,
transmission,
tcu,
crank pulley,
supercharger pulley and bearing, i
dler pulley,
changed gaskets, i
ntercooler pump(still the stock one),
seat heaters(both passenger and driver's side),
All those and other little things that I cannot recall at this moment. I still have some problems on it that need fixing. I still have to change my spark plugs and wires(got the original ones) and have to get a gear adaptation from mb because my car does not downshift all the time and feels sluggish.
2 x IC pump
2 x (yes twice, on the same door !) rear left door solenoid (pogo lock problem)
transmission sensor leak (twice)
shock absorbers at all 4 corners with bilstein B8
front wheel bearings
suspension arms bushings
front disc brakes and pads
code 3 pulley /filter
The only thing I've had to do other than maintenance was to replace the clutch bearings for the supercharger about a year ago. My mechanic tells me it's time for new plugs, which I plan to get done next week.
