Code3 Supercharger Pulley Review
The installation was very smooth. I followed the procedure as found on the Code3 pdf. almost exactly. The only modification I made was replacing the crow bar with a strap wrench to hold the pulley in place. The pulley came off without a hitch and went back on the same way. I installed the included shim for the spacing and torqued the main bolt to 20nm with my torque wrench.
Driving impression, WOW... This thing really hauls now. The power delivery at lower rpms are also amplified tremendously. It feels like there is more torque all the time. I highly recomend this product to anyone looking to boost the C32 to a new level. Thanks to the members who contributed with info and to Brandon for the great customer service.
Now...Time to install the package from APE
Albert Hernandez.
Just read this thread.
DON'T EVER BUY CODE3 products, unless you want to be ripped off!
Save your hard earned $ and buy from LET, aka "eurocharged"
Sorry to read your's was not so good.
Time to get to work on the IC pump
Albert Hernandez.
Albert Hernandez.
If you use the "search" function you will find that MANY support my view.
Glad you like the part Al.
Irish
AirFrcd really took one in the rear, and has very valuable advice for those willing to listen...
Irish
Thanks for the advice, but seriously fellas, you guys are missing the point...LET does NOT sell Supercharger Cltuch Pulleys!
Albert Hernandez.
LET made a baseline reading of 288 rwhp and 298 torque on a PowerChip tune.
It's unfortunate to hear some members' horrible experiences with Code3. No one would not want that to happen to anyone.
As of this writing, the bearing on the SC pulley is going out. I noticed it when
I drove in to my garage. Way too loud whining. I ordered immediately a replacement bearing Nachi 32BG05S102DST.
Funny thing, I squirted some Teflon oil lubricant on all the bearings I can get to and the noise went away but not completely.
I know I installed the Code3 pulley a little bit more than a year ago.
of course now would be a prime time for eurocharged to make a s/c pulley to benefit those that dont want the crank setup!
http://eurocharged.com/
The results dumbfounded everyone. I was second to last at 10:00 P.M. (started at 9:00? A.M.) and Jerry and everybody else just wanted to call it a day. He said he could tweek more out of it but basically, said it was a pretty good pull with just what I had for mods and the temp that day. There were guys with 185s and could only get a little bit over 310s rwhp.
Remember, LET just did a baseline reading. No tune! I'll have to waii till perhaps October when LET might be in town.
No, this was not on a Mustang. I believe it was a DynoMite.
Bottomline, sounds like he needed a specific part, sourced an upgraded version through C3P, and obtained a very satisfactory result. While I wouldn't necessarily order product from C3P, I don't think it's very fair or respectful to the OP to pursue an unrelated bashing session in his thread. My $0.02.
