Major Issue C55 2005 AMG Any Help or Idea's
Old Oct 6, 2009 | 03:59 PM
sac amg's Avatar
2005 C55 AMG
Lightbulb Major Issue C55 2005 AMG Any Help or Idea's
Hi Dan here I have a 2005 C55 with 125,000 miles my problem is when starting the car after 1 min or less the engine will surge up like I have tapped on the gas and it will do it several times, and when the car gets warm 10 minutes, later the engine idles very low and will stall out. it will stall at every traffic light. Here is the trick but after restarting the car 4 or 5 times everything then runs fine. all codes are working and no engine light is on but sometimes and even after the car has run for 2 hours I drive it allot it still will surge now and then and I have to keep my foot tight on the brake every stop its a strong surge the car will try to move or jump forward, any help on this issue I'm sure there are not that many C55 with 125,000 plus miles.
Old Oct 6, 2009 | 04:02 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
sounds like the (dreaded) TPS or thrtl posi sensor......any mods to the TB or sprint booster, ect?
Old Oct 6, 2009 | 04:20 PM
sac amg's Avatar
2005 C55 AMG
C55 Issue
Thanks for the tip I'm getting all the ideas I can and will work with my mechanic in San Francisco he is baffled so far and we have not called the factory rep yet but he was going to today. We have replaced several sensors but it fixed nothing, but have not looked in your area of suggestion . Dan
Old Oct 6, 2009 | 05:11 PM
testknight's Avatar
CLS55
Just to share...on the DOHC 4.6 Cobra, this was a common problem resolved by replacing the PCV Valve (easy, quick and cheap). They would get oil in them and get stuck.
Something to consider...unfortunately I am very new to these cars and haven't run through the gambit yet. Hope this helps.
Last edited by testknight; Oct 6, 2009 at 05:12 PM. Reason: bad speller and fat fingering
Old Oct 6, 2009 | 05:43 PM
sac amg's Avatar
2005 C55 AMG
Thanks testknight
Thanks another good tip it could be so much even emission system
Old Oct 6, 2009 | 07:09 PM
Tump43's Avatar
2014 E350 4Matic
I had a similar problem and it was the MAF. I got a code though. I beleve that if the tps is bad the car will not start.
Old Oct 7, 2009 | 09:16 PM
Quicktwinturbo's Avatar
CLS, SLK, ETC
Your car has a lot of miles.. You should consider changing simple stuffs as well.. Like Plugs, wires, coils, tranny oil, brake fluid.
It sounds like TPS issue or CPS..
Old Oct 7, 2009 | 09:36 PM
sac amg's Avatar
2005 C55 AMG
Thanks for all the tips nice picture better look in the garage looks just like mine Silver was not sure on the color when I picked it up my C55 and boy I'm happy really love the Silver color
Old Oct 8, 2009 | 10:17 PM
Viper98912's Avatar
Current: C217 V12TT AMG Previously: C55 AMG, SL65 AMG
I'm sorry about your problem, but I'm damn impressed by the number of miles you've got
Old Oct 8, 2009 | 10:38 PM
1qikctr's Avatar
Merc power
^^ Ditto.
Old Oct 8, 2009 | 11:01 PM
sac amg's Avatar
2005 C55 AMG
Bundle Of Joy
I must say at 125.000 miles I am very impressed with the AMG boys and girls I really have had some fun here, it's a very strong 55 I have always wonderd if some are stronger than other's buy the builder? Are they really all the same or are some faster and it shows, mine is a scramer and have never had a problem till this month.
Old Oct 9, 2009 | 07:22 AM
Sephiroth's Avatar
08 M5, 06 X3, 05 C55
I had a similar problem last winter. I replaced the fuel pump/filter and my baby has been running strong ever since.
Old Oct 9, 2009 | 04:45 PM
moosejaw's Avatar
none
i cant belive my car is older and i have less than half the miles.....
Old Oct 9, 2009 | 05:03 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
it might be the accelerator pedal, since its drive by wire. The accelerator sensor controls the opening and closing of the throttle body.
