New wheels for my 2003 c32
2003 c32 amg
I have the original 17inch wheels. I would like to upgrade to 18 in and would like to know if anyone has had trouble with vibration once they upgraded.
You shouldn't have any problems. From what I've gathered the only time people have vibration problems is when they have to use spacers. The bigger the spacers, the bigger the vibration. 35 is the correct offset, so there shouldn't be any problem. Plus, if you input your car model on tire rack they only let you look at wheels that will fit correctly.
MBworld Guru
white and whiter
you would only experience vibration with non hub-centric spacers OR if the hub-centric spacer are badly balanced/machined
vibration has nothing to do with the thickness of the spacer or with the spacer present or not.
a non hub-centric wheel without spacer can also cause vibration.
03 g35 coupe...........02 c32 Sold
that's pretty much a false statement.
2003 c32 amg
I dont think the OZ Botticelli are staggered. And if they are, its an odd size.
Tirerack is the best, they will sell you the centering ring that goes on the car.
For the money your spending ($1K + each wheel) on that wheel you can do better IMHO.
2003 C32T
Hello!
I have to buy new wintertires and saw this ad and just wonder if you think they will fit my 2003 C32? The size on the tires are 245/40/18 and they came off a 2007 CLS500 if that helps you in any way...
Thanks, Lars/danish
http://www.blocket.se/stockholm/Vint....htm?ca=15&w=1
Thanks, Lars/danish
2003 porsche 996 turbo
bottacellis arent 1k apiece. only 350$ from tire rack and come in staggered sizes. i know a guy with a new set maybe 3 months on the car with tires for around 1600 if you want to check them out. there are in colorado
