Resonator removal help
C32 AMG
I was going to remove my resonator myself in the very near future and wanted to do it properly. I need to know what to get and who or where to get it from. Thanks
I would take your C32 to a muffler shop. In order to replace the resonator you need to have access to a lift, a Saz-all and a welder. Items usually not found in most garages.
Muffler shop can do the job in about an hour. You will need to locate an approximatelly 2.5 ft. long 3'' diameter piece of stainless steel pipe to use as resonator replacement. Muffler shop might have it, but they ususally only stock aluminized steel. Good Luck.
C32 AMG
I have the the saz-all and welders, and access to a lift so we can do it. My father will actually do it for me, he does stuff like this all the time, He owns a Busch car. I just dont trust a lil muffler shop with a car this expensive. Thanks for your help!
also.....do you know when the headers will be available because they are the only reason I am removing my resonator?
Wow, it is great to have a dad with such credentials and tool access ;-)
If you can wait about 3-4 weeks, the headers will come with a stainless steel bypass pipe for resonator.
W211 E55 AMG, ML63 AMG, Past 996GT3,ZCPM3,Brabus C32,ML 500
Originally posted by bverotti
Can you guys give me an idea how the cars sounds like without resonator at :
Normal acceleration..rrrrrrraaaaghghghghghghghwweehhhh
WOT acceleration..puwpuwpuwpuw
just cruising ...
just cruising ...
SLK32 AMG
Normal acceleration
WOT acceleration
just cruising ...
Normal acceleration
WOT acceleration
just cruising ...
Originally posted by SiLvaC32
it will cost abit of HP?? i thought it should increase performance... if not, stay the same. not loose it.
Jerry
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
Jerry
This is my getto conclusion..
If it sounds faster, It must be faster..LOL
