Please help me fix my C32
Old Feb 10, 2010 | 08:36 PM
seth geckon's Avatar
'02 M3
I was driving my girlfriends car home from work today and I had driven about 15 miles. I was cruising about 55 mph and all of the sudden it just cut off. I coasted up to a stop sign and put the car in park and tried to restart the car. It started and idled horribly and then cut off again. I tried this a few times with the same result. I left the car for about two hours and went back and got it. It cranked up and idled bad but it could be driven. It was only about one mile to the house. I have been searching the forums and I have come across suggestions from the crankshaft position sensor to plugs and wires. I checked the codes and it listed multiple codes. P105(map sensor) & P300-P304(misfire of cylinders) The car was running perfectly until it just cut off earlier. Any suggestions on what I should check now. I am really at a loss. Sorry for the long post but hopefully someone can help me out.
Old Feb 10, 2010 | 08:41 PM
320 dreamer's Avatar
2003 porsche 996 turbo
sounds like a crank position sensor. very common on these cars
Old Feb 10, 2010 | 08:44 PM
'02 M3
Thank you for your prompt reply. That is what I had originally been leaning to before I ran the codes. I had read about how they tend to fail once the car warmed up and once the car cooled down they would work correctly again. Would it be a good idea to let the car cool down completely and crank it again? Do you think the car would run correctly until it warmed up?
Old Feb 10, 2010 | 09:02 PM
it should be. unfortunately the s/c engine only takes about 5 mins. to heat up and it may fail again. hopefully someone else will chime in as im only guessing. the codes certainly suggest some sort of timing irregularity
Old Feb 10, 2010 | 09:14 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
I had a vacuum hose at the rear of engine (passenger side @ t-splitter) which managed to disconnect itself completely. Caused severe hesitation...
Old Feb 11, 2010 | 04:10 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
same symptoms....happened to me last year most likely the cps as everyone suggests good luck
Old Feb 11, 2010 | 09:31 PM
'02 M3
Did your check engine light come on when this happened?
I went out this evening and cranked it up. The car had not been cranked in over 24 hours. Same rough idle and the check engine light came on immediately. It gave similar misfire codes and the map sensor code again. It also gave the malfunction about the battery/alternator needing to be serviced. Could this still be the crank position sensor? I will not be able to really check over the car until this weekend. Is it worth it to buy the cps and the map sensor?
Old Feb 12, 2010 | 12:11 AM
gt4awd's Avatar
CEL with MAP code thrown. Misfires were not saved. Probably pending... I got it resolved right away, so it didn't have much more than five minutes run time with the vacuum hose disconnected. By the way, it did throw battery/alternator malfunction too! I think you have a vacuum leak, and you should really check the vacuum line at the rear. It goes into the rear passenger side of the supercharger. Does the problem lessen as you gain speed?
Old Feb 12, 2010 | 07:02 AM
'02 M3
Yes the problem did seem to get better with speed. I will check that first. Thank you for your help.
Old Feb 12, 2010 | 09:27 PM
1qikctr's Avatar
Merc power
One its could be CPS, second, it could be your fuel pump. If the fuel pump is out the car shuts off rough idle. Or like some ppl said it could be a simple t splitter not plugged in.
Old Feb 12, 2010 | 09:34 PM
'02 M3
I pulled the air filter assembly off at the throttle body this afternoon and did some looking around. I could not even see the vacuum lines behind the supercharger. I tried following them from the front of the motor put could not. I also think I located the cps and that looks like that will be a tough job. Does anyone have a picture of the t-splitter in question? I don't know how it could be the fuel pump on the car because it will crank and run but it is misfiring badly and a very rough idle. I always thought that a fuel pump was an all or nothing thing. Thanks for all of the help.
Old Feb 13, 2010 | 11:59 AM
jayitx's Avatar
2004 Capri Blue C32
I had a similar problem a couple of weeks ago. I replaced the MAP sensor, but it didn't fix it right away. Gramma_Benz gave me this suggestion:
Try this:
With the car off and the key out, Unplug the cable going to the throttle body, it's right on top. Wait one minute.
Plug it back in, put in your key, turn to position two and wait one minute.
Start your car.
The first time I did it the car started fine. On the second start, it was havin the same problem again. I tried it again, checked all the vacuum lines, disconnected and blew air through the 2 hard plastic vacuum lines that run from the front of the car under the supercharger, and everything has been fine since then.
Old Feb 13, 2010 | 10:09 PM
gt4awd's Avatar
Look down in this groove, and you will see the vacuum line. It's connected as a pressure fitting. The solid pipe is held in place by the rubber piece... Not to say this is your problem, as it could be another line, or something else completely. This line is what caused the same exact issues for me though.
Old Feb 17, 2010 | 08:25 PM
'02 M3
I have checked the vacuum lines and all seem fine and I have replaced the crankshaft position sensor. The car still has the same issues. I have removed the map sensor and visually checked it and it was clean. I tried unplugging the harness going into the tps and following the steps about leaving it unplugged for a minute etc. and nothing seems to be helping. I appreciate all the advice and suggestions but does anyone have anything else I can try? If not, it will be going to the dealer shortly.
Old Feb 25, 2010 | 08:39 PM
'02 M3
A little update on the car. I have replaced the crank position sensor, the map position sensor and the camshaft position sensor. Cylinders 1, 2, 3 are not getting spark. I swapped the three coil packs from one side of the motor to the other. I also replaced the spark plugs. Cylinders 4, 5, 6 are firing as I would assume the should. What would cause the coil packs on cylinders 1, 2, 3 to not fire at all? Is there a fuse that could be blown or a connection that could have come loose? I am open to any suggestions. Thanks.
