Time to crank up the boost
Old Feb 22, 2010 | 02:33 AM
AMGSC's Avatar
2006 Weistec 3.0L SC'd C55, 2006 MaxPsi PT6466 Turbo'd M3, 2019 Maserati GTS , 2020Alfa Quadrifoglio
Well, car runs nice at 6psi and makes a respectable 426rwhp on a lower compression engine but we are now ready to take it to the max.
Here are some pictures of my larger crank pulley (stock is 150mm) and smaller SC pulley (stock is 78mm).
I'm looking for 15-18psi now that I found someone who can program around the MAF.
Attached Thumbnails Time to crank up the boost-picture-090.jpg   Time to crank up the boost-picture-088.jpg
Old Feb 22, 2010 | 05:47 AM
francoisisp's Avatar
AMG
well well well, subscribed
Old Feb 22, 2010 | 08:14 AM
superstar's Avatar
03 R230 SL55 / 94 W124 E500
Old Feb 22, 2010 | 08:19 AM
ABALONE's Avatar
2001: Supercharged E55 AMG
Great!! Looking forward to see the results
Thats some great power at only 6 psi, specially since you are on the 9.1:1 CR.
Are you only on a smaller water pump pulley for clearance? This should be the fastest C55 ever if you get things to work with the MAF.
// Magnus
Old Feb 22, 2010 | 12:28 PM
AMGSC's Avatar
The AFR is perfect at 12.67 at 6550rpm. The run was done in 80.45F, 30.16 in-Hg, 7% Humidity, Boost was 6.17 at peak.
Car no longer stumbles or stutters. Idles so quiet and smooth. So overall drivability is fantastic. The handling is amazing. It feels like those cars at the go-cart (Speedzone or Malibu Grand Prix) tracks. I can make a sharp right turn at 25mph without even hitting the brakes.
It took a while to get her done but with all the events that went on with Vadim's business interruptions, I understand why. At least she's running fine. If I want to stop now, I will have a car that can run another 150K miles without a problem but I never do so next step is to bring this 9:1 CR reinforced engine, tranny and suspension to the limits of it's potential.
Old Feb 22, 2010 | 08:34 PM
JonMBZ's Avatar
06 C55, 09 E350
hit 500 already please!
Old Feb 22, 2010 | 11:17 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
can you please share with us your plan on how you will run a larger crank pulley, larger supercharger pulley together synchronized with the ECU..? this will be very interesting..
Old Feb 23, 2010 | 03:32 PM
rockjock's Avatar
I DON'T COME HERE ANYMORE
larger crank,smaller SC pulley-
he stated he has someone who can program around the MAF (recently removed MAF with COP on an Evo up here-its wierd).
Old Feb 25, 2010 | 06:07 AM
saer1one's Avatar
ahh, passed me by..
Old Feb 25, 2010 | 11:12 AM
blackbenzz's Avatar
haters crazy
When? You should take your car to the track as is and see what it can pull in its current format. I woudln't consider a 12.5+ AFR at redline perfect on a boosted car but that's just me. How did you come up with the number 6.17PSI as your boost?
Old Feb 25, 2010 | 02:19 PM
AMGSC's Avatar
They had a boost meter attached during the dyno run.
Old Feb 25, 2010 | 04:00 PM
GuidosGottaBenz's Avatar
05 C-230 Kompressor
Subscribed
You should just it also!!!! HAHAHAHA
Old Mar 6, 2010 | 09:44 AM
blackbenzz's Avatar
haters crazy
Updates?
Old Apr 22, 2010 | 02:18 PM
blackbenzz's Avatar
haters crazy
Old Apr 22, 2010 | 05:46 PM
AMGSC's Avatar
Picking up the car today to drive for 1 week until Evosport opens up a block of time for the next phase. I am re-doing my entire exhaust and getting long tubes as well. Then the car will be prepped for high boost by using either AEM, MOTEC and PECTEL to accomodate 14-15psi (1bar). I will also have a unique INNOVATE product beta-tested on my car that actually does full data-logging by using my iPhone. Brad tested it on my car and it worked great according to him. It has not been released to the market yet.
The car got completely debugged and numerous small malfunctions were fixed due to all the electrical problems caused by the fire (alot of the wires actually melted) and had to be replaced. There were a bunch of vacuum leaks near the throttle body and elsewhere that were also refitted and tightened with professional braces and clamps.
There are no more CELs of any kind and the car has a clean bill of health for the major modding to begin.
A compression and leak down test was performed and it was exactly 150 on all 8 cylinders and 1%-2% leak down on all cylinders as well.
This will be my final series of mods before I call it quits with modding this car.
