My C55 vs new M3
Rating: Thread Rating: 2 votes, 5.00 average.
Old 03-22-2010, 04:05 PM
  #101
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Originally Posted by aho
hahahah, those are the only two pics I have or her unfortunately
FAIL! Who is she? Maybe we can look her up, lol.
Old 03-22-2010, 04:11 PM
  #102
aho
aho's Avatar
03 C32 AMG
Not a clue, took the pics from supraforums thread a couple years ago
Old 03-22-2010, 04:18 PM
  #103
Newzchspy's Avatar
PLAID
Originally Posted by wawy
The new M3 will walk any stock C32 or C55....
I am so glad you clarified that!!! Now, if any Newer E92 M3 wants to take on my Kleemann S7, I would be happy to oblige!! Of course, the M3 can be modded as well, so its all relative. I will say this though, I highly doubt a lightly modded E46 M3 will take a lightly modded (pulley and tune) C32 though!! You just can't beat the C32 SC for tuning and pulleys!!
Really, this debate has come up many times before and there's no reasonable answer about who will win unless we go to the strip, put down some $$ and let er roll. Fortunately or unfortunately, when we do Morrocco, there's very few, if any, M3s around???
Old 03-22-2010, 05:13 PM
  #104
BLKCLK550's Avatar
09 CLK550
I ran a Nismo 370Z
We did about 4 40 mph runs, i had a 250lbs passenger 370Z had only the driver.
Considering my clk is 3700lbs + me 180 + 250=4130 and he had 3200lbs + 160= 3360 i thought he might take me with his 350hp engine and light car.
I took him by about 3-4 cars i guess my TQ played a big roll pulling this much weight.
Old 03-22-2010, 05:42 PM
  #105
moosejaw's Avatar
none
Thanks for killing this thread,
at least you didnt show any photos of Stevie
Old 03-22-2010, 05:48 PM
  #106
Newzchspy's Avatar
PLAID
They're coming!!! Hey, we've been around this M3 V. C32 V. C55 block so many times, I am seasick!!! :
Old 03-22-2010, 05:54 PM
  #107
moosejaw's Avatar
none
Hah I found like ten! Hope Newzchspy didnt take any Viagra bc he'll knock over the table when he sees these.....
Old 03-22-2010, 05:58 PM
  #108
Super Moderator
nlpamg's Avatar
damn, her website is gone...
  #109
moosejaw's Avatar
none
Originally Posted by e1000
your username goes well with your post
E1000 wasnt far from the truth
Be Careful
link may have naughty images in case little ones are around
http://encyclopediadramatica.com/Renee_Nicole_Stage
Old 03-22-2010, 06:03 PM
  #110
PC Valkyrie's Avatar
C55 AMG, 135i, 911 GT3, GLE43 AMG
Thumbs up
Here you go:
C55:
Final Drive 3.06:1
1st Gear Ratio 3.59:1
2nd Gear Ratio 2.19:1
3rd Gear Ratio 1.41:1
4th Gear Ratio 1:1
5th Gear Ratio 0.83:1
E92 M3:
Final Drive 3.64:1
1st Gear Ratio 4.23:1
2nd Gear Ratio 2.53:1
3rd Gear Ratio 1.67:1
4th Gear Ratio 1.23:1
5th Gear Ratio 1.00:1
6th Gear Ratio 0.83:1
So in first gear it looks like:
C55: 376lb-ft * 3.59 * 3.06 = 4,130lb-ft to the wheels
M3: 296lb-ft * 4.23 * 3.64 = 4,557lb-ft to the wheels
Second Gear:
C55: 376lb-ft * 2.19 * 3.06 = 2519lb-ft to the wheels
M3: 296lb-ft * 2.53 * 3.64 = 2725lb-ft to the wheels
I could go on but the advantage is always there. Keep in mind the M3 not only produces more torque to the wheels, it does it until 8,400 rpm, giving it a significant advantage. Let it go, it's not a good race, from a dig, from a roll, in reverse, dosen't matter, just stop now.
You do seem like an educated man, but at least get your numbers correct.
You got the C55's gear ratios right, but I think your numbers for the E92 M3 are incorrect.
E92 M3 with 6 speed manual:
Final drive: 3.85:1
1st gear ratio: 4.06:1
2nd gear ratio: 2.37:1
3rd gear ratio: 1.58:1
4th gear ratio: 1.19:1
5th gear ratio: 1.00:1
6th gear ratio: 0.87:1
E92 M3 with 7 speed M-DCT
Final drive: 3.15:1
1st gear ratio: 4.78:1
2nd gear ratio: 2.93:1
3rd gear ratio: 2.15:1
4th gear ratio: 1.68:1
5th gear ratio: 1.39:1
6th gear ratio: 1.20:1
7th gear ratio: 1.00:1
Furthermore, it is highly unlikely that you will use 1st or 2nd gears when you are in the middle of a rolling race. Let's take a typical scenario where one is cruising at 60mph in highest gear. Then you want to play.
The C55 driver should downshift from 5th to 3rd (from personal experience, and from the fact that peak torque of 376 ft-lb in the C55 happens at around 4000rpm). In 3rd gear, the C55 should be at around 3658 rpm at 60mph (which is close to peak torque given the C55's relatively flat torque curve).
The E92 M3 (with M-DCT) should downshift from 7th to 4th. In 4th gear, the M3 should be at around 4110 rpm. This sounds like a reasonable gear to be in, because peak torque of 295 ft-lb in the M3 happens at 3900 rpm. This is also in keeping with what the M3 guys say: "not much happens in the M3 below 4000rpm".
In this situation, here are the torque numbers at the wheels using your equation.
C55 3rd gear: 376lb-ft * 1.41 * 3.06 = 1622.3 lb-ft
E92 M3 4th gear: 295 lb-ft * 1.68 * 3.15 = 1561.1 lb-ft
The C55 actually puts down MORE wheel torque in this type of situation. I'm not saying that the C55 will win the race, as the C55 will run out of revs to keep up with the high reving M3 which also has more gears. But it is POSSIBLE for the C55 to at least keep up at the beginning.
There are so many combination of factors at play when racing from a roll (the speed at which the race starts, the gear being used, etc). I'm just saying that the stories of a C55 keeping up for a short amount of time to a E92 M3 is POSSIBLE. We all know the M3 will blow by the C55 as the race goes on.
Old 03-22-2010, 06:05 PM
  #111
Super Moderator
nlpamg's Avatar
Be Careful
LOL, oh man. FAIL. that's a shame. lol.
Old 03-22-2010, 06:13 PM
  #112
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
WIN!
that's pretty ironic coming from you. last time I checked, 90% your posts were know-it-all, matter-of-fact type posts. so when someone actually is talking sense and you don't agree with them or your argument is getting destroyed, you'll accuse them of arguing just to argue...
Hence, why i let it go and said improiz was right. its a waste of time arguing with idiots on the internet. I didn't want RXL02 to fall under the same trap.
I really doubt 90% of my posts are about arguing. Since i probably only really argued with maybe 4 people out this entire forum.
Old 03-22-2010, 06:21 PM
  #113
jturkel's Avatar
02 C32 AMG
found her. her name is Ashton Von.
some links. racy, so i'll say NSFW
and apparently, she is a brunnete now. her tattoos and piercing still there though.
http://redblow.com/ashton-von-smoking-cigarette/
http://www.exhibgals.net/dd/udb524/thehun.html
http://pigtail-girls.com/Renee1/
http://www.bertsbabes.com/loverenee/renee.html
http://www.teenqueens.net/galleries/loverenee.html
http://www.regularpervert.com/babes/...uch/renee.html
i'm good
Old 03-22-2010, 06:26 PM
  #114
aho
aho's Avatar
03 C32 AMG
YEAHHHHH!!!!!!! Great job Josh and Moose!!!!!
Old 03-22-2010, 06:31 PM
  #115
e1000's Avatar
a quarter mile at a time
Final drive: 3.85:1
Final drive: 3.15:1
Assuming your numbers are correct (I may have looked up the wrong year, model, trim, etc) Why wouldn't the M3 be in 3rd for this little race? 4000 rpm in an engine that revs to 8,400 is nothing. 3rd gear also lasts till 92mph for the M-DCT numbers you posted. The result would be:
E92 M3 3rd gear: 295 lb-ft * 2.15 * 3.15 = 1997.9 lb-ft
  #116
Former Vendor of MBWorld
hooleyboy's Avatar
C55,SL55,C63
M3 E92's are gutless, when it comes to torque. On a tack its not about torque though.
Old 03-22-2010, 06:34 PM
  #117
Super Moderator
nlpamg's Avatar
yeah, there's really no point... especially when it comes to people that are on their high-horse and think they know it all, kinda like you, Captain Obvious.
re-read my post. I said that 90% of your posts were "know-it-all, matter-of-fact type posts" where you act as if you know everything. you may not think that they're argumentative, but when you try to lecture everyone as to what you think you know, they become damn annoying.
Old 03-22-2010, 06:35 PM
  #118
Super Moderator
nlpamg's Avatar
Old 03-22-2010, 06:44 PM
  #119
e1000's Avatar
Be Careful
I'm good at spotting them!
Old 03-22-2010, 07:16 PM
  #120
moosejaw's Avatar
none
Im at least good for sumthing!
Just a tip to you guys looking for photos of chicks
there is this website called www.tineye.com that searches the internet for a photo and comes up with links for it. Its pretty well used in the **** community to look up additonal info on academy award winning actresses.
Now maybe on a C55 final gear ratio vs a M3, i know nothing.
But when it comes to ****, even FrankW couldn't touch me.
Old 03-22-2010, 07:58 PM
  #121
TemjinX2's Avatar
I never said i knew everything, people post threads to get feed back from forum members. I posted what i know either from personal experience, knowledge gain from previous posts or just general research.
Some people disagree with me, others agree with me. You can take my posts with a grain of salt if you want.
I have disagreed with other members in the past, we have agreed to disagree and became better friends for it.
If my posts annoy you, just don't read them. It's very simple.
Old 03-22-2010, 08:01 PM
  #122
Super Moderator
nlpamg's Avatar
Thank you, Captain Obvious. It's posts like this that are just so utterly annoying. Get off your soapbox.
Old 03-22-2010, 08:03 PM
  #123
Super Moderator
nlpamg's Avatar
nice! good to know
*edit, so I finally used this thing. Jordan (kira_x2) had a picture of some girl on his f/b and didn't know who it was. well, this handy little website found more pics...
back to the thread:
edit*
Old 03-22-2010, 08:09 PM
  #124
e1000's Avatar
Oh is that what you were doing when you made that little comment a couple pages back? Real constructive.
Old 03-22-2010, 08:16 PM
  #125
TemjinX2's Avatar
Lol no problem. I'm actually off the soap box right now...i'm sitting on a chair at the moment.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: My C55 vs new M3
