What is this doing here???
I'm referring to the oily stuff at the bolts on top of the intake mani ramps.
Exhaust lubricant?? That doesn't sound so bad. A local shop said they thought it might be blinker fluid and that I would need a new motor.
Seriously though, valve cover gasket? How would that affect the nside of my intake plenum?
If it's intake plenum bolts that are seeping oil, then... it's either motor oil or supercharger oil, I'd guess.
And you don't need a new motor when you run out of blinker fluid. Just get one of of these:
http://kalecoauto.com/index.php?main...&products_id=6
And when you say new gaskets, what new gaskets? I've never heard of a gasket inside of an intake plenum.
Also, does anyone have a link to a complete diagram of this motor. Or a sequence of photos of one being torn down?
take off your airbox and check if you have the recirculating valve cover oil leak. leak from that area can slowly seep through all kinds of places.
btw, mine doesn't have much issue with excess oil that require a catch can, but seems like i'm one of the few.
https://mbworld.org/forums/w211-amg/...stock-awe.html
