Just change tranny fluid, or flush it?
Car has 78K on it, tranny has 20K on it ( i have no idea why, but the dealership replaced it in this car at 58K...long before i bought it) .
Should i flush it, or just drain and fill?
Thanks!!!
If you do the full flush you may see about 8 quarts. If you just drain it, probably 4-5 quarts.
EDIT: Here is a very good how to along with all the parts you'll need: http://www.benzworld.org/forums/w210...ion-fluid.html
How does the dealership flush it BTW?
What about just draining it, filling it back up with 4ish quarts and then just repeating the process a week later?
And is the filter easy to get to? And if there are metal shavings, will they be pretty evident?
https://mbworld.org/forums/c32-amg-c...n-service.html
Thank splinter for this one.
As Splinter alluded to in his thread, it may be worth your while to have your transmission fluid tested for glycol content.
That will likely influence your decision to 'flush' versus 'drain and fill'.
I figured I'd changed about 40% of the total volume, so repeated the process to get mostly new fluid in there. I didn't feel like tempting the gods by messing around with cooler lines for the flush.
