Where can i get the sl55 intake set up
Old Sep 28, 2010 | 03:04 PM
Jordan7589's Avatar
C32 AMG
Ive decided to just buy the whole sl55 intake for my c32 instead of buying th e parts because i would have to make some modifications to make it fit. i rather just do it right, and save myself the headache by just buying the whole kit and being able to "bolt" it right on. the only place i nkow that has it is tvt, is there anywhere else that has it or is that where everyone else gets it?
thanks
Old Sep 28, 2010 | 07:16 PM
320 dreamer's Avatar
2003 porsche 996 turbo
parts.com
113-090-01-29 Y AIR INTAKE PIPE
113-090-05-01 Box for Air cleaner left
113-090-06-01 Box for Air cleaner right
113-094-17-82 AIR TUBE to Air Cleaner left
113-094-16-82 AIR TUBE to Air Cleaner right
Old Sep 28, 2010 | 09:44 PM
Jordan7589's Avatar
C32 AMG
and those pieces will bolt right on using the stock mounting hardware?
Old Sep 29, 2010 | 08:35 AM
afaik. i think theres a little tweaking at the t/b for the spitter and you may need to tweak the front tubes so they connect thru the rad support. on my slk32 i needed to fab a small tab to slip into, the airbox slot were it mounts to the rubber mount. all in all not a big deal
Old Dec 19, 2010 | 07:20 PM
C_DirtyTwo's Avatar
a land yacht.
Can someone help me out.....
I found two different sets of part numbers and am not sure which one is correct to this date...
113-094-1682
113-094-1782
113-090-0601
113-090-0501
113-094-0103
113-094-2382
113-094-2482
=$299
(is this one splitting the Y-splitter into three parts?)
And the ones listed in one of the posts above:
113-090-01-29 Y AIR INTAKE PIPE*
113-090-05-01 Box for Air cleaner left*
113-094-17-82 AIR TUBE to Air Cleaner left*
=$320
Old Dec 19, 2010 | 08:53 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
113-094-1682
113-094-1782
113-090-0601
113-090-0501
113-094-0103
113-094-2382
113-094-2482
=$299
=$320
113-090-01-29 is the right part number. What you are listing are some (but not all) of the components that make up the 113-090-01-29. I also don't think that MB sells individual parts that make up the 113-090-01-29. But I may be wrong. The omissions may account for the $21 difference.
Old Dec 19, 2010 | 09:12 PM
C_DirtyTwo's Avatar
a land yacht.
With shipping it comes out to $370 when less than a year ago people were getting the set up for $100 less!! What the heck, did the prices go up or what??
Old Dec 19, 2010 | 09:48 PM
Lenin's Avatar
I don't think that the price for a new full setup was ever less than $300. There is also a possible upgrade for the inlet hoses. You can get this:
a2730900182 KEVLAR INLET LFT
a2730900082 KEVLAR INLET RT
They handle the heat much better. But they are $45 each.
Old Dec 19, 2010 | 09:55 PM
C_DirtyTwo's Avatar
a land yacht.
there was a post by Jturkel back in september saying he got his full SL55 intake off parts.com for $280
that means that now a new SL55 intake with k&n's is over $470....
Old Dec 20, 2010 | 01:35 AM
Lenin's Avatar
You are welcome.
Old Dec 20, 2010 | 07:49 AM
try searching for a e55 setup instead of a sl55 setup. the airboxes are the same but cost less for the sedan
also the y splitter and tubes are no longer sold separetly. its a pkg and the price vs individual pcs is higher.
bottom line is if you wanna play you gotta pay!! look at the price for my needswings dual cai and you getting off super cheap! of course the dual cai flows about 350 cfm more air
Old Dec 20, 2010 | 03:16 PM
C_DirtyTwo's Avatar
a land yacht.
Thanks for the help Lenin and 320 dreamer! I found a way to get the price at wholesale without having to pay for the shipping expenses, so I will be getting it for just under $300 for the complete set up which is ideal for me. Thanks again guys!!
Old Dec 20, 2010 | 03:20 PM
badblackbenz550's Avatar
benzo larenzo
can you please share where you go it ? i need one also
Old Dec 20, 2010 | 03:59 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
are the CL55 airboxes the same? They are the only parts I need to complete my 55k intake
Old Dec 20, 2010 | 07:17 PM
all of the s/c 5.5 engines use the same airbox setup.
Old Dec 20, 2010 | 07:28 PM
Lenin's Avatar
In support of the above, w211, w215, w219, w220, w230, w463
Old Dec 21, 2010 | 03:19 AM
Rabble's Avatar
c32 amg
parts.com
I have a question. When to choose a box for air cleaner and Airbox to air cleaner, so it has lots of different options. For different model years, etc. Which one is correct?
Old Dec 21, 2010 | 08:08 AM
AMGC's Avatar
alright thanks for verifying.
Old Dec 21, 2010 | 05:06 PM
airbox holds the filters air tube runs from the rad support to the airbox and y splitter connects both sides together at the t/b
Old Jul 25, 2011 | 07:45 PM
WaveyKat's Avatar
Something Slow
113-010-09-67 Front Cover so expensive :-(
Old Jul 30, 2011 | 08:07 PM
ByeTurboS4's Avatar
'02 C32 ///AMG, 2000 BiTurbo Audi S4(RIP)
What's the front cover?
Old Jul 30, 2011 | 08:33 PM
jturkel's Avatar
02 C32 AMG
i believe he is referring to the SL55 engine cover
Old Jul 30, 2011 | 09:08 PM
he is but it wont fit the v6 engine . cut the mount tabs off the oem cover and reapply with epoxy and it will fit the sl55 boxes.
Old Jul 30, 2011 | 11:42 PM
saer1one's Avatar
2002 c32 AMG 2012 c250 Coupe
Does anyone know which is more effective, the sl55 splitter or the code3 intake..? Anyone done a dyno on both of these..?
Old Aug 2, 2011 | 07:05 PM
C_DirtyTwo's Avatar
a land yacht.
I had both, I'd say the SL55 splitter. If you think about where the code3 is sucking air from it's basically all hot air unless you are at high speeds.
