Custom Intercooler System - Interested?
The price will likely be around $800-$1000. This includes pump, heat exchanger, intercooler, reservoir, piping, etc... A full kit. The company has a heat exchanger which I believe will work perfect. The product is specifically designed for water to air, and used in many race applications. If you already have a Eurocharged or other the kit can be purchased without for less.
My plan is to locate a second intercooler in the battery bay away from all the heated engine bay temperatures. The stock intercooler will still be utilized to cool the charge air first, which will then move on to the second larger, and more efficient intercooler, and back to the throttle body. A battery relocation to the trunk would be required. The reservoir will likely be located in the truck spare tire well too if there isn't room after placement of the intercooler.
so then at this point, what is the purpose of retaining the stock intercooler? to just "help" a little with the new one that would be added? i mean, temps will still be hot in there b/c of it's placement, but i'm willing to bet with a supplemental IC, they won't get as hot. it'll just start cooling the stock one and get even colder int he aftermarket one.
....as far as a pump, i would imagine we might even need a higher flowing pump b/c of probably a decently sizable increase in volume? i mean...1) additional I/C , reservoir in trunk....piping, that's all gotta add some decent volume
but as far as if i would be interested or down? yes. you show me some gains, i'm down.
just as a side, i feel that most that would be down already have a heat exchanger and/or aftermarket pump (that i do NOT have lol....still staying stock b/c i dont trust the CM30/johnson....i heard from somewhere that it flows too much for our current setup, causes backup at the intercooler, and then leakage)
do you think a) there would be a benefit of adding an additional H/E if b) we could fit another one somewhere (can we?)
so i monitor my IATs. granted i have a 185 and i drive hard, temps are still not "cool" per say. driving 90-100 degrees outside, it'll easily be 130s. i can say that at the drag strip, finishing off the 1/4, i've seen temps north of 160 or 170 (i think?...i dont recall).
like this
I've also notice if the humidity is higher the intake temp actually drops for some reason.
as for the slr style i/c ... i can see too much hassle when replacing the spark plugs and wires.
While I think the idea for cooling is good, I think this could be accomplished more efficiently and increase performance by doing top mounted intercoolers. When I have some time, I'll post the research that I have been gathering about the top mounted intercoolers. Essentially it integrates the manifold with the intercooler and so it creates more air and does not sandwich the intercooler between the engine and supercharger, making it more efficient.
I think if you want to cool a bit more, I would look into water/meth injection to cool the air after the intercooler. I think that would be cheaper and allow you to cool when you want to.
clean is nice, functional is better. if we do a top mount through the intake manifolds, maybe we could makes those a bit bigger too....
Honestly, I don't really care for the look of the ones that Vadim built, but really like the modified SLR ones.
Bell Intercoolers
Custom Intercoolers/Cores, US Made,
Air/Air and Liquid/Air, 3000+ Sizes
bellintercoolers. com
If you want more power look at the CF board......Colin posted up what he had done to his car, and strangley enought was the same stuff I had on mine when I broke into the 11's. (then again we built it so not so surprising whats on the car)
In any event, it would literally be the only timeslip in the 11's for a C32 - a shame for it not to be documented (IMHO).
