Pic request - C55 with lowering springs only
2013 C63 AMG P31, 2014 GMC Sierra (6.2)
Guys,
Can you post some pictures of your C55s lowered with springs only. Please indicate which rear spring pad thickness you used (if any).
2016 Chevrolet SS, 2006 Cadillac STS-V
The shocks and struts are actually made by Sachs. I bought my set used and not actually from Renntech. As far as I know all W203s suspension is interchangable (coupe may be different, not sure). I would say call Renntech directly instead of their vendors and find out if there is any difference. I know in the shocks the C55 strut has the 12mm hole for the sway bar end link (which could easily be changed), but I don't know if there is any different valving or anything like that. I wouldn't think the springs would be different but I'm not 100% sure.
I think you are correct. Also, their catalog only lists the following for springs:
C CLASS
All models equipped with coil spring suspensions
SUSPENSION UPGRADES
1. Lowering springs 322030095
I will call however..
The question isn't really if they are interchangeable, but if its actually beneficial to performance to run a cup kit thats been dialed for a different weight. I'd imagine the front end of our cars is significantly heavier than that of a normal w203 due to the engine.
