HELP! Transmission dead, part needed!
From the pictures i've taken you can see the horizontal needle bearing. the red arrow pointing is where the broken needle bearing suppose to be. anyone know where or whom I can get this part from? I'm gonna try the stealership tomorrow too to see if i can get a quote. Any advice and comments are more that welcome.
TIA!
thanks in advance!
First off, you have some major cojones to just wake up today and decide to take apart your transmission. A transmission is the most precise and fragile item in a vehicle.
I hope there was a good way that you specifically determined that your transmission was making noise and not the engine. I'm hoping getting a new needle bearing in there will do the trick, but I'm not 100% sure.
Looking at the placement of that needle bearing, it looks like it's purposefully a flexible poly cage with a slit in it (it's the only way to get it on the shaft between to flanges). By your description that it's plastic and is broken in pieces does seem to make sense.
I've looked through all the EPC drawings that there are for the C55 trans, and it looks like the needle bearing you're looking for is A 140 981 12 10. The issue is that the shaft it seems to be riding on is not the shaft you've shown. So currently I'm not sure if this answer is right, unless you can take some more pictures for me of the your breakdown process. I was only able to piece together everything with limited visuals (since I personally have not taken this specific transmission apart).
The other thing I was going to say is that it may be very very hard to try to find this needle bearing. These parts (at least from my company) weren't available to the public. If we determined this was an issue, we'd send a full replacement transmission. You're probably going to have to go to a major manufacturer's site (SKF, ***, NSK, INA, etc) and piece together what part number you may be looking for. Then the hard part will be finding this part for consumer retail.
Good luck, and send me some more pictures if you can so I can confirm.
Today I got another source with a newer part number: 140 270 62 28
From the pics, you can see the plastic band has a different pattern like squares. the old one didn't have this. all the dimensions are similar to the old one. The guy also told me that this part he has already changed for several people already, hmmm I never knew this was a part prone for failure. I will be converting/adding an external tranny cooler as heat may also be the cause for the plastic to weaken in the first place.
Good news though, my mechanic buttoned up her this afternoon and we took it out for a little drive. No more noise and shifts very clean. I also replaced the clutches while it was down. Tranny temp was 194F.
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_4112wt_888
I found out I also got a crack in the welds of the EC headers.
its off to the welders right now. Hopefully I can get her back tonight
The famous 1.5k rpm jerk is gone, i can hardly feel the torque converter lock-up. Before it was very very noticeable, felt like a gear change. The parts that were replaced was: the clutch (4 rings) and the "plunger" within the housing assembly. I'll get the part numbers. cheers~
