Seat Heater Issue 2006 C55??
Old Dec 6, 2010 | 11:32 AM
Newzchspy's Avatar
PLAID
The drivers side seat heat started acting up on the 06 C55? I had this problem on the C32, BUT is it an known issue on the C55???
Old Dec 6, 2010 | 06:08 PM
mkonei's Avatar
05 C55
My drivers side cushion has been out for a while, common prob i think. the pass side cushion works though, ive been thinking of switching them
Old Dec 6, 2010 | 06:22 PM
thtguy's Avatar
2017 GLS 550
Seems the Heater Elements are not designed to be sat on everyday, I believe they physically break.
Old Dec 6, 2010 | 07:01 PM
91RS's Avatar
2016 Chevrolet SS, 2006 Cadillac STS-V
I had my bottom one replaced on the driver's seat. I'm not sure if they actually break or get burned up from being used. GM heater elements usually burn up, but they also typically last quite a while before that happens.
Old Dec 6, 2010 | 08:17 PM
vvcobravv's Avatar
2006 C55 AMG
Had mine replaced... The replaced the bottom half of the seat, needless to say they should have replaced the entire thing because they look two tone from the wear...
Old Dec 7, 2010 | 12:30 AM
RLx02's Avatar
C55
I assume not an easy fix?
Mine went out a while ago...but my back warmers work well still....more important than the *** warmers I think.
Old Dec 7, 2010 | 01:35 AM
Quicktwinturbo's Avatar
CLS, SLK, ETC
It's a common issue on C55.. I replaced mine 2-3 times by dealer.. They actually changed the entire bottom section (instead of just changing heat'n pad).. And yes, it's not working anymore.
Old Dec 7, 2010 | 06:54 AM
91RS's Avatar
More like expensive, the element only comes as part of the seat cover.
Old Dec 7, 2010 | 08:00 PM
RLx02's Avatar
C55
gyah...ridiculous :/
Old Dec 8, 2010 | 12:55 AM
MIKESV8's Avatar
Aston Martin V8 Vantage
the question is, how much do you weigh? jk i have never personally had a problem with mine partially because i've used them twice since i've bought the car just to see if they work. maybe people on here can tell you which fuse is for this (maybe the level lights wouldn't work either if that were the case) or take a power tester and see if there is current going into the mechanism. i couldn't imagine cost on a new one though
Old Dec 8, 2010 | 01:15 AM
CLS, SLK, ETC
Enjoy it while you can.. cuz bottom part will go out sooner or later
Old Dec 8, 2010 | 11:29 AM
Newzchspy's Avatar
PLAID
Before or after the numerous marathons I run?? I lose about 5-6 lbs per race in water weight and calorie burn but average between 165-170!!!
FYI, had the same problem in the C32 BUT it was a factory repair (warranty) at the time. Does anyone know if they are covering this under a TSB for the C55??
Old Dec 8, 2010 | 03:18 PM
MIKESV8's Avatar
my CPO warranty ends on the 21st of this month, i checked it again this morning and it worked fine. i'm gonna have them replace the engine mounts very soon though, i heard those go bad. it would be nice if someone can come up with a list of stuff for the dealer to go through before my car goes out of warranty. knock on wood i've never had any real problems with my car.
Old Dec 9, 2010 | 07:43 PM
pealei392's Avatar
Both seats in my C32 fail to heat. I called the local Benz delaer a few dasy ago. They quoted me $1300 to fix one seat bottom! I searched some other threads on the topic and saw where others only paid around $800. Could be dated though. Either way It's an expensive fix.
Old Dec 10, 2010 | 12:59 AM
viper501's Avatar
06 C55
Had driver's replaced about 3 times under warranty. Passenger once. POS design or materials?
Old Dec 10, 2010 | 04:23 AM
MIKESV8's Avatar
MY DRIVER'S SIDE *** WARMER DOESN'T WORK!!!!!!!!!!! oh well, warranty ends on the 21st, another addition to my list of stuff to take care of
Old Dec 10, 2010 | 04:57 PM
Tump43's Avatar
2014 E350 4Matic
My driver's side a-- warmer is out for the third time, after having been repaired twice under warranty. I've learned from this forum that these seat warmers break internally the second you kneel on them or put too much pressure on any one small portion of them. The only real fix, besides the Stealer, is to buy an aftermarket seat warmer insert, remove your seat, open the stiching on the back of it, slide out the OE seat warmer insert, replace with new, restich and reinstall. One of the threads shows which aftermarket instert to purchase.
Old Dec 10, 2010 | 05:47 PM
Newzchspy's Avatar
PLAID
I got my C32 drivers seat repaired under a TSB for the seat heater BUT was asking if anyone knows if they are repairing the C55s seat heaters the same way. My C32 was way out of warranty when it went bad??
Old Dec 11, 2010 | 10:32 PM
Slater126's Avatar
2002 C32, 2011 VW GTI
Probably. I had the heaters replaced on my '02 under warranty in the fall of 2007 (they actually replace the upholstry since the elements are built-in) and the driver's side bottom heater died again last winter. It started getting really hot and eventually just stopped working.
So I imagine it is a design flaw common to all W203s, given that the new elements broke too. I'm not going to bother replacing it with my own money given that I don't trust it will last. The back still works, which is good enough for me. If your car is out of warranty, you may want to think twice about paying to fix it with an OEM piece. Aftermarket is probably the way to go.
Old Dec 11, 2010 | 10:40 PM
BrandonS's Avatar
'05 C55
Mine's out as well only on the bottom. Quoted, by a Euro shop (not dealership), at $540 for part (they have to buy from Mercedes), and total of $900. I have an aftermarket warranty. I need to call Monday to see if it's covered. I'm hoping it is, they covered the seat electronics/motor/track when the passenger seat died.
Old Dec 11, 2010 | 10:44 PM
Slater126's Avatar
Wow. Given that it may only last a year or two, I don't know if I'd pay that unless it would be under warranty.
Old Dec 11, 2010 | 10:54 PM
BrandonS's Avatar
'05 C55
Yea i told them not to order it until i find out if it is covered. I told them for that amount of money I can wait for the car to warm up. They laughed and agreed. These seats are no joke though. My pass seat electronics went out and made the motors fight each other and burn out. They ended up having to cut out the seat, install the new motors/track assembly and electronics unit. That was $2000. Covered under warranty. My warranty cost me $1950 so I'm already ahead; the company has 65,000 miles and 4.5 years left of covering me.
