Hitting rev limiter in 1st gear, why?
Old May 8, 2003 | 07:30 AM
scmguru's Avatar
I've been hitting the rev limiter in 1st gear a couple of times now, both times the car was in full automatic mode. I assume this should not be happening.. is there something I can do? Anyone else have this issue?
Old May 8, 2003 | 08:53 AM
misu55's Avatar
2002 C32 AMG
WOW! You've been hit the rev limiter?!?!? I think car broken yours is.
Old May 8, 2003 | 09:33 AM
alz's Avatar
alz
Who are you?
Yoda?
Old May 8, 2003 | 11:33 AM
Zeppelin's Avatar
C32
I think they all do it occasionally. Going to have to live with it unless you get an aftermarket chip that raises the rev. limiter. Sucks when it happens though.
Old May 8, 2003 | 12:22 PM
my401's Avatar
c32
never
Never, before or after ups.
Old May 8, 2003 | 02:37 PM
jswedberg's Avatar
C32 AMG
I have not ever had it happen, either. I thrashed it pretty hard a couple of weekends ago at a time trial and never had a hiccup.
Old May 8, 2003 | 03:10 PM
Mach430's Avatar
Mike,
It is not normal for your car to do this. Call the service rep I mentioned to you in the PM and ask him if they can look at it.
Thanks,
Ben
Old May 8, 2003 | 04:40 PM
Zeppelin's Avatar
C32
This was a pretty common gripe about 18 months ago, I'm sure it will happen with any C32 at some point. So no one hear has almost hit there head on the steering wheel on the 1-2 shift? Does not happen very often, but it does.
Old May 8, 2003 | 08:10 PM
Shine's Avatar
Exclamation
The cases I've heard of is the protection interlock of S/C overheat.
Go for the dealer & connect the DAS , you can read all those error messages.
Old May 11, 2003 | 04:16 PM
sfkarp's Avatar
2004 E55 White
Mine did that a few times also. When I brought it in for the first service I told the service adviser about it. They ordered some parts (a valvle body I think) and reprogrammed the computer. I have not had it happen since then. This fix made my car shift a little smoother also.
