Super Charger Sound w/ video help
Old Feb 14, 2011 | 12:12 AM
Budget Baller's Avatar
2018 GLE350
Since buying this car the supercharger has always sounded "funny". It's almost impossible to describe the sound so I created this video in hops I can get some feedback from the experts here
Can someone listen to the video and tell me if this sounds normal?
http://www.youtube.com/watch?v=oAr3aeuGaSs
Old Feb 14, 2011 | 03:44 AM
2018 GLE350
107 views... anyone? I can post a better video if needed. Any feedback would be greatly appreciated.
Old Feb 14, 2011 | 03:57 AM
ddtham's Avatar
C32, 911 SC
I think it sounds normal. If your SC bearing goes bad, you should be able to pick up the rattling sound with a stethoscope (sp?).
Old Feb 14, 2011 | 04:12 AM
2018 GLE350
hu, well I suppose thats good to know. Its much more noisy in person, almost sounds like a generator. When I'm inside the car I really don't hear anything. But when I'm in the drive thru etc and the car is against the wall, it looks like a million dollars but sounds rickety. But if that's how it's supposed to sound then cool And thanks for the reply!
Old Feb 14, 2011 | 12:22 PM
mdncn2762's Avatar
1992 Toyota Corolla, 1994 Chevy C1500, 2002 C32, 2012 Prius, 2013 Toyota Sienna
This does not sound normal at all to me. Are you sure its coming from the S/C and not the Alternator or water pump????
Old Feb 14, 2011 | 02:17 PM
ddtham's Avatar
C32, 911 SC
Mine has that rickety sound too, but when I went to my local MB specialist, he mentioned that it's normal. It hasn't given me any problem despite the fact that mine is modded.
To OP, the best way is to find another C32 in your area and compare them or go to your local indie shop and find out.
Old Feb 14, 2011 | 02:40 PM
jturkel's Avatar
02 C32 AMG
+1. mine does not sound like this at all. doesn't sound like it's a bearing thing either.
Old Feb 14, 2011 | 03:56 PM
2018 GLE350
That's actually exactly what it sounds like now that I think about it, a bad steering wheel pump. BUT the sound is coming from the super charger.
If I place my ear right by the front of the super charger (where there are two screw holes) thats where the noise seems to be coming from.
Old Feb 14, 2011 | 04:06 PM
Newzchspy's Avatar
PLAID
Give us some history on the car, how old?? You the original owner?? Mileage? Any modifications??? What kind of SC pulley, crank pulley (185, 178??) Code 3 pulley?? I am trying to differential diagnose here and see if its bearing or the SC???
You can take a piece of hose and try to specifically locate the noise by putting it on the "problem area" and then to your ear (carefully of course) to isolate the sound.
Old Feb 14, 2011 | 04:12 PM
2018 GLE350
From head to toe everything in the car is OEM. I just purchased the car about a week ago from a buddy in Texas. I believe he was the 2nd owner. Car has 105k on it.
I can grab a hose to locate the problem area a bit better but I'm 98% sure it's coming from the front of the supercharger. It's much louder in person and easy to located. I took it to my brother who going to mechanic school. He has no experience with superchargers but at first thought it was the pulley. But when we both got closer we agreed it's coming from the inside of the Supercharger towards the front.
If you look on the video you can see 2 holes toward the front of the super charger, from there all the way to the front of the charger is where the noise seems to be coming from.
Old Feb 14, 2011 | 05:52 PM
c32kompressor's Avatar
CLK55 AMG
That sounds weird to me aswell. Just a guess out of the dark but could the screws in the SC be going bad? Actually now that I think about it have you ever changed the oil in the SC? If not you should do that. I'm planning on doing it as soon as I get the oil from the stealership
Old Feb 14, 2011 | 06:03 PM
gt4awd's Avatar
2005 Pontiac GTO 6.0 LS2 - Blue
Here's why I don't think it's the supercharger internals. The electromagnetic clutch is disengaged during idle, and the rotors are barely moving... You can grab the clutch itself, and stop it from spinning. I guarantee you'll have the same sound. Not sure by just hearing a sound clip what it could be. However, the power steering pump is located in that general area. First step would be to replace the supercharger pulley bearing IMO.
Old Feb 14, 2011 | 06:07 PM
2018 GLE350
gt4awd You make a really good point actually. I didn't think of that.
My brother should be back from the college in an hour or so. I'll cruise over to his house and have him take another look.
One more question about the bearings - If I remove the belt and turn the super charger pulley, I'm guessing it would be pretty noticeable if the bearings where bad correct?
Old Feb 14, 2011 | 06:10 PM
gt4awd's Avatar
Yes, you'll be able to hear the bearing sound by spinning the pulley. Mine is about due for replacement. Getting louder every month...
Old Feb 14, 2011 | 06:20 PM
2018 GLE350
Alright well I'll try to report back on this later. I'll probably order some bearings anyway, may as well replace them.
Old Feb 14, 2011 | 10:47 PM
2018 GLE350
ok so after looking at the car more today we noticed that the sound is actually more towards the back but definitely coming from the super charger.
It's not the power steering pump he checked that and said it was fine. In a nut shell we're not sure wtf the problem is So we're going to drive it up to the college tomorrow if possible. Apparently one of the guys specializes in Mercedes. So fingers crossed.
I did notice another thing today, when you turn off the car, that same noise is very noticeable. Almost sounds like there are marbles jumping around for about 2 seconds as the motor turns down.
Temp fix for now: turn up the radio.
Old Feb 15, 2011 | 04:28 PM
gt4awd's Avatar
I would be careful driving it. You're probably hearing a bad valve...
Old Feb 15, 2011 | 11:54 PM
2018 GLE350
Well we took the belt off and spun the pulley. Sounded brand new to be honest. (looks new as well) I didn't mention to my brother that gt4 said it could be a bad valve be he said he's sure that isn't the issue.
The sound, whatever it is, still seems to be coming from the Supercharger. Either way, I'm going to try and take it to the tech at the school tomorrow if he has time. Guy is supposedly familiar with C32's
Old Feb 16, 2011 | 03:02 AM
alkrstev's Avatar
Silver 02 C32 & White 05 CLK500
That sc doesnt sound like the one in my car. Hey maybe you should try to replace or add some more supercharger oil to the sc. Maybe it is running on dry? Check out this thread:
https://mbworld.org/forums/c32-amg-c...-their-sc.html
Old Feb 16, 2011 | 03:16 AM
Viet_Amg408's Avatar
Pinto
your coupler is bad..bushing is worned
Old Feb 16, 2011 | 05:37 AM
2018 GLE350
GREAT thread. Thank you! I'm going to do this regardless. I just rush ordered the Mobile Jet Oil as well as they syringe. We'll see how it goes. Should be here by Friday.
Old Feb 16, 2011 | 05:38 AM
2018 GLE350
Not sure where the coupler is but I'm sure my brother will know. I'll send this over to him tomorrow Thanks
I figure if all else fails I"ll just take it to the deal. Sorta like taking your Taxes to the IRS...
Old Feb 16, 2011 | 01:41 PM
Pinto
Similar to this
http://www.youtube.com/watch?v=pSsSctYvOoI
Old Feb 16, 2011 | 04:04 PM
2018 GLE350
If it does end up being the coupler where is a good place to purchase the replacement part?
Also is there anything I can do to verify it's indeed the coupler? When we took the belt off and spun the SC pulley everything seemed smooth. No sound really.
Old Feb 16, 2011 | 05:30 PM
Pinto
yea, if your bearing are ok.. then its your supercharger coupler is worned..too much freeplays...
Im planning to do my S soon..
here's a ref: its in Vietnamese Lol
http://www.otofun.net/threads/175311...ger-kompressor
parts:
http://cgi.ebay.com/ebaymotors/SUPER...item5197da13b7
