Stuck half-way through removing C32 accelerator pedal
Hoping someone can point me in the right direction - following the other threads on here I've done the following..
Using a screwdriver popped the plastic plug off the 10mm nut and then used a socket wrench to undone it.
Using needle-nose pliers pulled out the pin from the top of the pedal.
So then the pedal can rest forward on the cabin floor - but I'm stuck - I can wiggle the assembly - but can't see how to take it off. If I try to lift the unit - it doesn't move up enough to clear the 10mm screw that the nut goes on. Seems like there's something at the very top of the assembly - holding it kinda in place - as I said I can wiggle it - but don't want to force it.
What have I missed?
Cheers
Ed
I'm trying to get the whole assemblage out - not just take the pedal off. Trying to fit a sprintbooster myself.
Is there any other part I need to loosen/nut I need to un-do to remove the assemblage?
Is it just the 10mm nut and the accelerator pedal? or this another part?
Ed
Thought I'd finish this off, installed the sprint booster or is it sprintbooster today.
The problem I'd had was that under the 10mm nut, which I'd removed, was a washer, that was holding th bolt in the centre of the hole, giving me no wiggle room, once id also removed the washer the whole accelerator assemblage came out.
I only learnt that after I'd removed the noise-canceling foam/plastic under the bottom of the console to get a better look at the top of the assembly, which was totally unnecessary. There is no 3rd step, it.s 1.) remove pin, to allow pedal to drop forward 2.) remove cap, then unscrew 10mm bolt and washer. That's it.
I drive an Australian c32 so was also worried that the sprint booster wouldn't fit, there's another post about that problem, well thankfully not an issue, series 2 with the led button fitted and works fine.
Ed
