taking my C32 to the track for the first time tomorrow
Old Apr 7, 2011 | 01:46 PM
C32vsU's Avatar
2003 C32 AMG
I bought my C32 in November and have done the 181mm pulley and jerry tune. Then had to replace my IC because it was leaking, recently slapped on Hancook V12's. Car feels like a damn rocket, I came from a 300C with some mods that dyno'd out at 317 at the wheels and ran a 13.9. I know this will be much fast just by the feel.
Does anyone have any tips for me as far as running the car?
Old Apr 7, 2011 | 01:52 PM
xxaarraa's Avatar
Multiple
Put away a lot of money for repairs!
Just kidding, have fun and be safe.
Old Apr 7, 2011 | 01:55 PM
C32vsU's Avatar
2003 C32 AMG
I just dropped a ton on this car, can't stomach any more. Hopefully she holds up!
Old Apr 7, 2011 | 02:16 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
Asssuming you're going to the 1/4 mile track....
https://mbworld.org/forums/w211-amg/236339-drag-racing-how.html
Old Apr 7, 2011 | 02:17 PM
C32vsU's Avatar
2003 C32 AMG
Yeah 1/4 mile, I hoping for good times, we usually have a good DA up here, especially this time of year.
Old Apr 7, 2011 | 03:21 PM
chris.bachman's Avatar
a car.
Grip it & rip it.
Old Apr 7, 2011 | 03:57 PM
ddtham's Avatar
C32, 911 SC
Good luck and keep us updated with numbers!
Old Apr 7, 2011 | 04:10 PM
C32vsU's Avatar
2003 C32 AMG
Oh I will post my times................. with slip!
Old Apr 7, 2011 | 11:10 PM
AKnight55's Avatar
2012 C63 BS & 2014 E63 Estate & 2008 CLK63 BS
Get there early and give the car some time to cool down.. Lines get pretty long by the end of the night.. (Although maybe not this early in the season) Good luck
Old Apr 8, 2011 | 07:20 PM
C32vsU's Avatar
2003 C32 AMG
Ran
So I ran a 13.2 but conditions were no good. They didn't even spray the track cause it was too cold. At the end of my last run the check engine light came on and it went into limp mode. Got home and noticed a plastic cover on one of my intake hoses was almost off. This was on the left side and about 12" away from front of the car. I replaced it and started the car back up and light went off. Do you think that was the cause of the cel light?
Old Apr 8, 2011 | 11:20 PM
Lenin's Avatar
2002 C32 AMG, 2013 GLK 350/4, 2015 E63S AMG Wagon
It could have been over boost code. P0238. I get it sometimes at the track if its cold. If you don't clear it, it goes away by itself after a while.
Old Apr 9, 2011 | 10:50 AM
Newzchspy's Avatar
PLAID
+1 overboost very common with 181 and cold weather. Should go away after some running and several starts. 13.2 is on the low side with your mods. What was your speed? About 103-105??
Old Apr 10, 2011 | 11:38 PM
c32used's Avatar
LET C32 2002
practice,practice,practice
Old Apr 10, 2011 | 11:48 PM
MIKESV8's Avatar
Aston Martin V8 Vantage
I really could've used this thread a few weeks ago
Old Apr 11, 2011 | 11:06 AM
C32vsU's Avatar
2003 C32 AMG
the code that threw was P0108 so I believe it was getting too much air, so I think it was because of the loose peice on my intake hose. My trap was about 104 to 105.5 at best. when you say that time was on the low side do you mean I could do better or that was already a very low number. I would expect to be able to break into the 12's
Old Apr 11, 2011 | 02:23 PM
Newzchspy's Avatar
PLAID
P0108 Manifold Absolute Pressure/Barometric Pressure Circuit High Input
MAP sensor???
When I say that the time is on the low side, I meant that in a negative sense. With your mods, you should be in the 12s for sure (assuming you can hook on those new Hankooks??) Rephrasing, if its on the high side, a 13.2 is almost what a stock C32 is doing. I'd expect a 12.8-12.9 for those mods. Maybe even a 12.7 with a good hook-up. You should be at 107-110.
A time slip would certainly help us??
Old Apr 11, 2011 | 02:36 PM
C32vsU's Avatar
2003 C32 AMG
time slip
here is the slip, I hope you can read it, what do you think about the code I threw?
I didn't think 2.075 was a horrible 60' time, but it felt slow
File Type: pdf
Old Apr 11, 2011 | 02:56 PM
AKnight55's Avatar
Not a horrible 60', considering traction is usually an issue there.. More practice and you might in the 12s..
Old Apr 11, 2011 | 03:03 PM
C32vsU's Avatar
2003 C32 AMG
I will get the car into 12's, The only thing I am running right now is the 181mm pulley and a tune. there are a whole bunch of small things I could do to gain me some time. The hancooks I ran with had about 20 miles on the LOL, and they did not spray the track because it was too cold, I am hoping those things made a difference but maybe I am just being optimistic.
Old Apr 11, 2011 | 04:27 PM
Newzchspy's Avatar
PLAID
Get a less than 2 60 foot time and you'll be in the 12s;; the 105.05 is a pretty good MPH for that run, so you're making some power up top. FWIW, and as an example, there are cars with your MPH in the 12s at 107 which is only 2 mph more than what you're running. A better 60 foot time will certainly help that........You're not that far away!!
Old Apr 11, 2011 | 04:29 PM
C32vsU's Avatar
2003 C32 AMG
my 60ft was 2.075
Old Apr 11, 2011 | 06:19 PM
Newzchspy's Avatar
PLAID
Originally Posted by C32vsU;4619514[B
]my 60ft was 2.075
Every guy in the 12s is less than 2.0 including myself. A 1.7-1.9 would be preferrable. If you're not racing anyone and going for time, you don't have to "nail it" as soon as the tree goes green. Clock doesnt tick until you hit the timing light. Ahmed (Blkbnzz) is the master of this and is a good study in a qtr mile run.
"Spinnin ain't winnin"
http://youtu.be/86z1MxsSjyo
Old Apr 23, 2011 | 11:19 PM
AKnight55's Avatar
Hey man, good to see you at the track.. Are you sure your IC pump is working?? That might be the issue as to why your not in the 12s.. My best run when my pump wasnt working was a 13.2, now my best is 12.2, so it certainly would be worth checking out..
