Warning SL55 intake is not a direct bolt on mod.
W211 E63
![Thumbs down](https://mbworld.org/forums/images/icons/icon13.gif)
I ordered the parts after seeing the original thread here:
https://mbworld.org/forums/showthrea...threadid=39254
but the parts that I ordered
113-094-01-03 --- y-connector
113-094-23-82 --- hose
113-094-24-82 --- hose
does not fit. The outlet on the stock C32 air box is simply too small to fit the inlet on the 113-094-23/24-82 see picture below.
I was wondering how did you guys made yours fit, or maybe I got the wrong part?
This is what Vadim and I have been saying since the beginning. You have to make the proper ducting for it. Incorrectly done, you will lose power.
Thanks,
Ben
Thanks,
Ben
![Lightbulb](https://mbworld.org/forums/images/icons/icon3.gif)
Read Vadim or Ben's opinion to do the right thing right.
air mass sensor cost $510 and will be easily broke for improper
intake hoses hook up.
I order the SL55 Y pipe & hoses for V8 kompressor, I got
the SL55 intake boxes & engine cover already.
W211 E63
Originally posted by box986
Isn't most of the air mass sensor broke because of the additional dirt/fine particles that passes thru aftermarket filter elements NOT because of the additional air "volume".
It's just an electronic stuff
I heard some enthusiasts often connect/disconnect hoses
found frequent airmass failure than stock users.
For example they always try colder plugs,different hi-flow filters
lighter pulley.... put on/off the cover & hoses very often
the risk of improper hookup arised.
Shine: how much did you pay for the Carlsson strut tower brace? I thought its not supposed to be sold separately from the RS complete car?? Will you be able to get one more for me?
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
Evosport said they're Carlsson agent in the states.
If you wanna pick it up here, no problem.
![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
