Ugh...first problem after warranty came up. Battery/Alternator warning
Nothing seems to be acting up. Is it possible the alernator's failing? What kind of cost am I looking at? Oh, and I do know of a good 3rd party Mercedes authorized repair shop. I should be good taking it there versus a stealership, right?
its probablay just the voltage regulator... if when it gets warm the voltage starts to fall and charge at 11-12.5 volts than you need a regulator not the whole alt ... they are replaceable separate from the alt....
you would be amazed how many alts are repalaced when all was needed was a voltage regulator ...... just a hint from your scummy "stealership" tech.
I mean, $1800 for a belt replacement? I can buy a LED TV with that!
When I had an idler-pulley failure, the entire repair was in the ballpark of $1,800 (from an MB specialist indy) because the idler sheared off the waterpump-housing mount and they replaced the WP as well. The idler also trashed the oil cooler, so that had to be replaced. Etc etc.
When the pulley failed and sheared off, the first symptom was the "batt/alt" warning message... pulled over, popped the hood, and the belt was off, along with the idler and subsequent carnage.
My point is, no way was a "we replaced your broken belt with a new one, but that's all we did" a $1,800 job. My $0.02.
https://mbworld.org/forums/w211-amg/...lternator.html
Again, this is for the W211 E55 and I'm not sure how much would be applicable to the W203s.......
Hello everyone, can someone please provide some feedback on this tread, last night while idling my E55 in the garage I smelled a faint burning scent, popped the hood and could not find nor describe the source of this burning smell, however, after checking the forum on the matter it's come to my attention that the alternator/voltage regulator could be on it's way out, convienience message comes on and off now so i know there is low voltage (11.1v) sometimes a bit less, here's my question,,, if, it is the regulator thats bad, would I still get the burning smell???? Or is the burning smell a clear sign that the alternator itself is toasted internally....feedback please!!!!!!!
