H&R Coilovers: Known Clearance Issues?
Old Oct 10, 2011 | 01:48 PM
pww's Avatar
pww
'05 C55 AMG
Just ordered a set, and was curious if anyone here is running them and if they had any clearance issues. Wheels are currently 18x8.5 et35 18x9.5 et 35, and while spacing them out is in the near future, I was curious if I'll be able to have the coils installed before I throw on spacers.
Thanks,
Pat
Old Oct 25, 2011 | 02:07 PM
W203Ramos's Avatar
'03C32 Obsidian Black, '76Toyota Celica GT TRD, '12R350 4matic Arctic White, '06 ML 350 arctic white
Thanks,
Pat
according to some of the responses I have gathered, you should bu fine unless you plan to SLAM the car. please let me know how the outcome is if you don't mind. I'm on 19"s and am planning to get H&R coils as well.
Good luck with the installation
John
Old Oct 25, 2011 | 03:35 PM
Gramma_Benz's Avatar
2002 C32, 2012 S550
I have tien coilovers and USED to have 19's. For me, it rode way too hard and I had a lot of rubbing in the back, esp. under hard cornering. So I went back to OEM. 18's would probably be fine though...
Old Oct 25, 2011 | 04:51 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
You will need to run spacers up front otherwise you will rub the perches. You need around et 27 to clear the perches on any set of coil overs. Your rear offset is fine.
Old Oct 25, 2011 | 07:55 PM
AMGC's Avatar
Mosselman 190E 16V+ C63S+ Abarth 595
with the right size tire, you can always get away with little to no rubbing. Plus nothing is better than a perfect stance with the right amount of stretch on some nice rims.
Old Oct 25, 2011 | 11:39 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
^ Listen to this man.
With so many tire and wheel dimension variables, there’s no telling actual clearance until an in situ test inspection and verification can be carried out.
Note tire-to-strut leeway is substantially reduced owing to the coil-over’s circumferentially threaded housing and perch height.
OE and most replacement MacPherson struts include an indentation to help minimize lateral interference.
From the archives, my former Koni, Michelin 245/40/17 and 34 ET setup:
Another member's KW fitment:
unknown photo credit
Old Oct 26, 2011 | 01:48 AM
pww's Avatar
pww
'05 C55 AMG
Thanks for all the tips guys. I already have spacers for the front and rears, it looks like I'll just order the bolts I need for them (I have conical, need ball seat) and throw them on when i put the coilovers on. Now to find a DIY on the install to decide if I should do this on myself.
Old Oct 26, 2011 | 11:41 AM
C_DirtyTwo's Avatar
a land yacht.
I have KW's and I have to run a 10mm spacer up front. Even with the spacer I rub a little on the coil, but not enough to really bother me. My coils are as low as they will go though, so that may be the issue.
Old Oct 26, 2011 | 02:30 PM
loudandheard's Avatar
C32/C55 AMG
http://www.mymbonline.com/forum/160-...-included.html
Old Oct 27, 2011 | 01:51 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Everytime I see pix of Splinter's set up, I wish H&R made a set of "super sport" springs to really get rid of the gap for the w203. I would totally run koni yellows + super sports and 245 up front!
Heads up: pww - front spacers on our cars are "special" in that there is a little lip. not any ol spacers will fit. Check out H&R's webpage to see the difference.
ps - this is a free bump for the other thread.
Old Oct 27, 2011 | 08:04 PM
pww's Avatar
pww
'05 C55 AMG
No worries I already have a set I was running for my last wheels, just need the bolts.
Thanks again for the info guys. I'll be running an et20 up front, which some of you might think is too aggressive but I think it should work. Will probably run a 12 mm in the back for a 9.5 et 23 for a nice stance. Should come together well. Might move down to a 225 in the front too.
Old Oct 28, 2011 | 02:19 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
ET 20 up front is totally do-able esp on a c55 w/ wider front fenders. Put the baseball bat and heat gun onto the fender liners a bit and you'll be fine. Im running ET 25 up front and rub only when im almost at full lock. So it only happens when im going really slowly anywho.
Now, ET 23 in the rear, thats gonna be harder I tried to run ET 21 + 9.5" + 255/35 and I just BARELY rubbed. TONS of poke. Looked cool, but I think ET 25-28 in the rear is more realistic w/ 255. Unless you wanna break out the fender roller (which I wouldnt mind doing, I just dont wanna mess it up)!
Cant wait to see your results Esp w/ the rotiform NUEs
Old Oct 28, 2011 | 06:38 PM
pww's Avatar
pww
'05 C55 AMG
Yeah when I take it to have the coils installed (decided I won't do it myself this time around, I have my passat to break ) I'll have them give the fenders a roll, don't think they will need a pull though. I ran an et21 in the rear on a 9.5 for a while on my stock suspension, and it rubbed pretty bad. I'll have to see, cause sitting at et35 is just not gonna look right I don't think.
Old Dec 27, 2011 | 05:46 PM
pww's Avatar
pww
'05 C55 AMG
Just an update for curious peeps:
Coils installed, they are great, a little on the soft side, but still good. Fronts are all the way down, running an 18x8.5 et20 with a 225, no problems.
Rears are at 18x9.5 et 23, slight rubbing with a 255, with the coils pretty low (tucking some tire)
As for clearance:
Obviously with my 15 and 12 mm spacers (front and rear respectively), I had no problems. However, I ran a 5 mm on the front and no spacers on the rear, and had no problems. So for H&R's, you can run an 18x8.5 et 30 front, and 18x9.5 et35 rear, with no problems.
