C32 faulty boost sensor, causes SC to cut out
When i slowed the car down a bit and then hit the pedal again, everything would be back to normal, sc engaging and all, back pushed against seat.
Today I finally got time to check it out and it turned out to be a small problem. STAR gave me a P0108 Error: Manifold Absolute Pressure Circuit High Input.
The part that got replace is designated as B28 in star service manual. EPC has the part no. A 004 153 33 28 . The old part has the same part number, so no updated parts.
Update: There is a new part no. P/N: A 005 153 72 28 Thanks OD!
Attached are the location of the sensor, part no. and some installation pictures. as you can see the sensor is actually located on the "charge air cooler"
Steps to change the boost sensor:
1) remove both air filters
2) remove the throttle body
3) remove the right intake manifold facing engine ( Driver side )
You will be able to use an extension wrench to remove the 2 screws holding the sensor.
After replacing the sensor and buttoning her back up, I took it out for a test drive. So far I cannot reproduce the SC cut out and acceleration is smooth as butter. I will test it out for a few more days and hook it up to STAR to see if there are any other error codes. Will update this post after. So there you have it.
. Mine acts like its going to downshift and you hear the sc but then the car jerks and no sc. I hope the symptoms dont come back for you. I am going to probably do this myself too.
FWIW, I think that P0108 is the code that all of the 185 guys/gals get from time to time. Overboosting the stock MAP sensor capacity. Should be most likely to occur in cooler, drier weather and at lower elevation. I don't think it's harmful or damaging to the car, but you should see about datalogging your car and make sure your AFRs are good even during the most demanding conditions (i.e. WOT, max load through the highest gear you can safely test, probably 3rd).
I m using iPhone (Rev) and Kiwi to monitor my IAT and it go over 100C, but the SC still function ok. I m guessing my apps detection having problem cause I m using a JB version
https://mbworld.org/forums/c32-amg-c...r-part-ii.html
On the EPC when I looked when doing this project came up with a new p/n along with a few gaskets that were different. I went to the dealer and order the part number that was on the EPC, This is what I got,
I did my tuning in the dead of winter here and speeds of up to 150mph using real world data logging ( don't ask me where ) And i send my data back to Jerry to have it retuned. Did this about 3-4 times to get it right.
car behaves normally all times until i smash it down full throttle on 2nd 3rd 4th gears it cuts gas totally doesnt accelerate anymore i press the pedal its empty and all i can do is park sbhut down restart and here it gors again...on 1st gear if im not goin sideways seems it doesnt do any problem...nota: car does function perfectly as long as i dont press the pedal fully or do a kickdown i even can go 200km/h without problem...any ideas???????plz help
i guess this exactly what u r talking about the boost sensor...it showe failure symptoms after a harsh driving night goin to speeds above 250 several times...opinions plz, any idea about the cost of this sensor?thnxx
man i changed my ic pump two months ago surely not from it, and from driving experience a failing ic pump will shut down on 160 k or so and will fail on high revs i can go up to 5800 with no problem so thats why i eliminated that option..
