What lug bolt shank size do I need?
I know I'll need a conical 12x1.5 thread pattern, but what's the right shank length?
I called up my local Discount Tire and they said that 20mm will work (it's the only size that they have). But I started to doubt that when I read this thread where a C32 owner with Bremmas said that he is using 27mm. Are the C32 and C55 shank length requirements the same?
https://mbworld.org/forums/c-class-w...nt-know-7.html
I know there are a couple of members here who have or had owned a set of Bremmas. Can somebody confirm once and for all the right length to use for a C55?
https://mbworld.org/forums/c32-amg-c...-our-cars.html
But practically, if you want to be sure, you could get the wheels, remove your stock wheels, try the existing bolts and then see how much more 'penetration' you may need.
So I just borrowed their 20mm bolt and there's around 1.5" thread that penetrates through the Bremmas I have in the trunk. Will this be enough?
I guess I'll just have to risk just going back in case their 20mm turn out to be insufficient.
In terms of safety, I should get at least a minimum of 6 full wrench turns when tightening the bolt right?
Bill
Thanks! So 1.1" threads, which that translates to 27.94mm.
You don't have any spacers right?
And how does it look from behind the hub? Does it fit flush (no protrusions)?
Amazon.com has it for $40.16, is this a good price or is there a cheaper place to get these?
However, I found these that are immediately available. Will these work too?
http://www.amazon.com/Gorilla-Automo...2592867&sr=8-1
Only difference is that the heads require a special key for installation and removal right?
No spacers with my wheels, and they fit fine without any rubbing of the fender lip. The lugs also don't hit anything behind the hub (which the stock-length lugs did).
Bill
