Help one where to hook up a oil catch can
2002 C32 AMG
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I've been wanting to install a aftermarket oil catch can but im not sure where to hook the lines up. I see on the drivers side valve cover the line goes to the intake, but on the passengers side it appears the line is going to the bottom of the throttle body if so should I route both lines to the catch can and cap off where it was originaly connected to the throttle body?
2003 porsche 996 turbo
both sides go to the catch can. the pass side y at the t/b is capped off and the return from the catch can goesa to the t/b. look at needswings catch can for the c32. its reasonably priced and a complete kit with every thing you need
this defeats the purpose of the catch can. the vacuum made from the t/b draws the filtered fumes back into the engine to be burnt. the can catches the oil particles to be drained later. the way your wanting do just moves the oil laden fumes from one side to the other. the y tube is already in the t/b. a simple rubber cap seals one side off and allows the catch can to work
2002 C32 AMG
just remember theres more going on inside the catch can than meets the eye. stainless steel mesh media and more. look at robs setup its the best out there for your car and looks factory when installed. the price is spot on the best deal going
C32 AMG
Thanks!
C32 AMG
